Still, that green laser diode, not even lasing, barely visible under dark conditions by a camera, at distance, going through that pin-hole opening was clearly detected.
Since there are random empty junk detections, I wonder if you used 2 tubes with an and-gate to eliminate noise and a beam splitter at the input to drive the 2 tubes in parallel. With the proper spacing, maybe only entangled photon pairs will be detected.
