Author Topic: How to Build a Switching Power Supply  (Read 8521 times)
Offline mediaTopic starter
  • Country: cn
« on: January 24, 2018, 10:20:13 am »
This switching power supply was built because I needed powerfull adjustable power supply for laboratory purposes. Linear topology would be unusable for this power (2400W - 2.4 kilowatts!). So I chose the switching topology of two switch forward (half controlled bridge). In my article about SMPSs it is a topology II.D. The switching upply uses IGBT transistors and is controlled by the UC3845 circuit. The schematic of my switching power supply you can see below. Mains voltage goes first through EMC filter. It is then rectified and filtered on capacitor C4. Due to high capacity, there's an inrush limiting circuit with Re1 switch and R2. Relay coil and fan (from PC power supply AT / ATX) are powered from 12V, which is obtained via resistor from 17V aux supply. Select R1 so that voltage at the relay coil and the fan was 12V. The auxiliary supply circuit uses TNY267. It is similar to described supply described here.  R27 provides undervoltage protection of auxiliary power - will not turn on when less than 230V DC. UC3845 control circuit has the output frequency of 50kHz and a maximum 47% duty cycle. It is powered through the zener diode, which reduces the supply voltage of 5.6 V (ie to 11.4 V) and also shifts the UVLO thresholds of 7.9 V (lower) and 8.5 V (upper) to 13.5 V and 14.1 V. Source then begin work on power 14.1 V and never run below 13.5 V, which protects the IGBT from desaturation. The original thresholds of UC3845 were set too low. The circuit controls MOSFET T2, which drives gate drive transformer Tr2. It provides galvanic isolation and floating drive for upper IGBT. Via forming circuits with T3 and T4 it drives gates of IGBTs T5 and T6. They then switch rectified line voltage (325V) to power transformer Tr1. Its output is then rectified and finally averaged and smoothed by coil L1 and capacitors C17. Voltage feedback is connected from the output to pin 2 of IO1. The output voltage of the power supply can be set using the potentiometer P1. Galvanic isolation of the feedback is not necessary because the control circuit is connected to the secondary SMPS side and thus separated from the network. Current feedback is fed through the current transformer TR3 into 3 pin IO1. The threshold current of the overcurrent protection can be set by P2.
Transistors T5 and T6, diodes D5, D5 ', D6, D6', D7, D7 ', and the bridge should be placed on the heatsink. Diodes D7, capacitors C15 and protective RDC snubbers R22 + D8 + C14 should be placed as close as possible to the IGBT. LED 1 indicates operation of the supply, LED 2 indicates the current mode (overload / short circuit) or error. It lights up when the supply is not working in voltage mode. In voltage mode, on the IO1 pin 1 is 2.5 V, otherwise it is about 6V. LED lights can be omitted.
Inductance: Power transformer Tr1 I salvaged from an old powerfull 56V switched power supply. Transformation ratio of primary to secondary is about 3:2 to 4:3 and the ferrite core (EE shape) has no air gap. If you like to wind yourself, use a similar core as in the inverter So about 6.4 cm2 (acceptable range is 6-8 square cm). The primary is 20 turns of 20 wires, each has diameter of 0.5 to 0.6 mm. The secondary 14 turns of 28 wires together of the same diameter as primary. It is also possible to make windings of copper strips. On the contrary, the use of a single thick wire is not possible for reasons of skin effect (as it works with high frequencies). Halving the winding is not required, you can for example wind primary first and then secondary. Forward gate drive transformer Tr2 has three windings, 16 turns each. All winding are wound at once, by three twisted insulated bell wires. Is is wound on the ferrite core EI (EE may be) without air gap. I salvaged it from the main power transformer from a PC ATX or AT. The core has a cross section of about 80 to 120 mm2. Current transformer TR3 is 1 turn to 68 turn on the ferrite ring and the size or number of turns is not critical. In case of different number of turns you have to adjust R15. Auxiliary power transformer TR4 is wound on ferrite EE core with air gap and the cross section about 16 to 25 mm2. It comes from the auxiliary power transformer gutted from ATX. Orientation of winding of transformers (marked by dots) must be followed. Double choke EMI filter can be eg from microwave. Output coil L1 also comes from a 56V SMPS I gutted. It consists of two parallel inductors 54uH on the iron powder rings and the total inductance is therefore 27uH. Each coil is a wound by two magnet copper wires 1.7 mm diameter. The total cross section of L1 is then approximately 9 mm2.
L1 is connected to the negative branch, so the cathodes of diodes have no RF voltage and can be mounted on heat sink (or part of it) without insulation. Maximum input power of this switched power supply is about 2600W and efficiency at full load more than 90%. In this switching power supply I used IGBTs of type STGW30NC60W. They can be replaced by the types IRG4PC40W, IRG4PC50W, IRG4PC50U, STGW30NC60WD or similar enough powerful and fast. The output diodes can be any ultrafast with enough current rating. The upper diode (D5) sees 20A average current in the worst case, for the lower diode (D6) it 40A. The upper diode thus can be selected for half current than the bottom one. The upper diode can be eg two HFA25PB60 / DSEI30-06A or single DSEI60-06A / STTH6010W / HFA50PA60C. Bottom diode may be two DSEI60-06A / STTH6010W / HFA50PA60C or four HFA25PB60 / DSEI30-06A. Heatsink of diodes must dissipate a loss of approximately 60W. Loss of IGBTs can be up to 50W. The loss of D7 is difficult to predict because it depends on the properties of Tr1 (its inductance and coupling). Loss of the bridge is up to 25W. Source uses similar schematic as welding inverter since it works well. Switch S1 allows standby shutdown, because frequent mains switching of this powerful supply would not be appropriate (especially when used as laboratory power supply). Consumption in the standby state is only about 1W. S1 can be omitted. The supply is also possible to construct for a fixed voltage source. In this case it is advisable to optimize the transformation ratio of Tr1 for the best efficiency (eg, primary 20 turns and sedondary 1 turn for every 3.5 - 4V).
     Attention!!! Switching supply is not for beginners, because most of its circuits are connected to mains. The mains voltage can occur on the output when improperly constructed! The capacitors can remain charged to dangerous voltage even after disconnected from mains. The output voltage can be above the safe touch voltage. This is the switchning power supply of high power. The AC input must have proper fuse, power outlet and the cable must be dimensed for the drawn current, otherwise there is a risk of fire. Everything you do, you do it on your own risk.
The schamatic of the high power adjustable switching power supply (SMPS) of 3-60V, 40A
Completed switching power supply
The front panel of the switching power supply - voltage control, current limit control, standby switch S1 and LEDs.
Box from the 56V supply ready for installation of my 3 - 60V supply
The original front panel
Box with 8cm fan.
Heatsink, Tr1, L1 and C17 of the old power supply that will be used for construction of my supply.
Prepared D5 and D6.
IGBT a reset diodes D7 on heatsink and the board prepared to be dremmeled.
Completed GDT (Gate drive transformer) Tr2.
The making of the board begins.
Completed power section, the control circuitry and the Tr2.
Building the auxiliary supply.
The board out of the old supply with LED 1 and LED 2.
Auxiliary supply afted the Tr4 soldered to it.
The switching power supply and the C4 capacitor (3x 680u)
Dummy load for testing of of the switching power supply: Spiral 230V 2000W from boiler adjusted to 57.5 V 2000W. I joined three branches, middle and both ends of the spiral are one outlet. The second outlet are tapped to the 1/4 and 3/4. This spiral is divided into 4 equal parts connected in parallel. The rated voltage is reduced the quarter, the resistance of the sixteenth and power is maintained.
The glowing spiral after connected to the tested switching power supply.
EMI filted and the inrush limiter.
Testing the switching power supply with the bottom of the box.
The inside of the completed supply.
For more information, I googled adjustable switching power supply and I found this article, which help me know more about the working principle of that sort of thing. Read it if you need:http://www.apogeeweb.net/article/62.html
« Last Edit: January 24, 2018, 10:34:50 am by media »
The following users thanked this post: Zero999
Offline T3sl4co1l
    • Seven Transistor Labs
Re: How to Build a Switching Power Supply
« Reply #1 on: January 24, 2018, 05:53:05 pm »
Nice, and it's actually current mode too. :-+
What's the electrical noise like?
Curious, why peak current mode control + half wave forward converter topology?
Seven Transistor Labs, LLC
Offline janoc
« Reply #2 on: January 24, 2018, 09:05:08 pm »
Hehe, "zlate ceske rucicky" (the OP will understand). That grey knob was a dead giveaway about where is the design from even before seeing the labels.
Nice job  :-+
Offline AllTheGearNoIdea
    • AllTheGearNoIdea
« Reply #3 on: January 24, 2018, 09:05:55 pm »
Amazing work very impressed.  I used to design switch mode power supplies many years ago. The most blew up and sometimes quite spectacularly. My next job was in software .
Chris
AllTheGearNoIdea Where Its All About The Gear
Offline nctnico
« Reply #4 on: January 25, 2018, 09:45:22 pm »
I find this project both fascinating and horrifying. It is obvious a great achievement to built something like a 2400W PSU this way so I'm going to take my hat off and make a deep bow. The part which horrifies me is the large amount of exposed lethal voltages and wires.
The following users thanked this post: fourtytwo42
Offline james_s
« Reply #5 on: January 25, 2018, 09:55:52 pm »
It is pretty impressive, in that mad scientist sort of way.
Offline sphinx
« Reply #6 on: January 25, 2018, 11:45:01 pm »
this project was previously on this site now this project is offline on this url
danyk.wz.cz/reg60v.html
i copied the info from there in jan 2015
The following users thanked this post: Mate_Well
Offline BravoV
  • +++ ATH1
« Reply #7 on: January 26, 2018, 12:10:18 am »
Google cache -> http://webcache.googleusercontent.com/search?q=cache:IZu0yl-KNGYJ:danyk.cz/reg60v_en.html
Yep, apparently the op did this single 1st post wonder just for spamming.
Reported.
Offline dave_k
« Reply #8 on: January 26, 2018, 10:31:23 am »
it is now here
http://danyk.cz/reg60v_en.html
Offline IanMacdonald
    • IWR Consultancy
« Reply #9 on: January 26, 2018, 11:59:20 am »
I was trying to figure out if this is a forward or flyback converter. Initially it looks like a half bridge primary side, but in fact both of the IGBTs are effectively in series and only seem to drive the transformer with one polarity.  Since the secondary has only half wave rectification I assume the flyback energy is dumped back to the supply via D7 and D7'.
Congratulations on getting this working anyway. Not an easy project.
Offline T3sl4co1l
« Reply #10 on: January 26, 2018, 07:38:00 pm »
Yeah, "two switch forward converter". Worthwhile because it handles reset flux without an ugly hack (i.e., adding a reset winding, or burning it as power dissipation in a clamping circuit).  Can also be used for flyback, with the advantage that leakage flux is handled similarly well, but with the constraint that output voltage can't be higher than mains input voltage times transformer ratio, which results in low duty cycles for wide input voltage ranges.
Also somewhat better than using two transistors in push-pull, which doubles the voltage requirement -- when one transistor turns on, the other side of the primary swings up the same amount.  However, I'd say arguably not better than half bridge, where you need a few more capacitors, but the transformer can be smaller.
The following users thanked this post: IanMacdonald
Offline chris_leyson
  • Country: wales
« Reply #11 on: January 26, 2018, 07:48:35 pm »
Nice but scary at the same time  :-+. Half bridge forward, nice topology much better than push pull. Good to see current mode control as well and I like the transformer drive for the IGBTs  :-+
