As mikeselectricstuff said, it is unusual for the feature to be missing.
For everyday use, it would depend on what you use the scope for. I tend to use it a lot, for seeing small AC ripple on top of a large DC voltage. You can AC-couple the signal to get rid of the DC offset and then crank up the scale to see the AC component easily.
