Author Topic: coolest looking components  (Read 25230 times)
Offline Artlav
  • Country: mon
    • Orbital Designs
Re: coolest looking components
« Reply #50 on: February 25, 2016, 04:12:29 pm »
Radar modulators: for when you need an IGBT, but they haven't been invented yet... ;D
33kV, 40 Amps pulse rating, a megawatt and a half in MHz range of modulated frequency.
I'm not sure there are IGBTs for that kind of scale even today.
But yeah, the thing took 300W just to heat up...
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #51 on: February 26, 2016, 04:18:19 am »
AFAIK, radar modulators were usually just for switching PFNs, so didn't have to handle pulsed CW; an IGBT would do just as well (and indeed, does to this day, as pulsed klystrons are used in particle accelerator applications; I don't know anything about modern radar, but they probably still use pulsed magnetrons in the simpler (commercial) ones?).
If you needed to do pulsed CW at a few MHz (probably not much over 30MHz, given the size of the thing), you'd be able to get off more than a few cycles of something pretty mean, though. :)  It would be pretty expensive to do the same (or at much higher frequencies) with SS.
Seven Transistor Labs, LLC
Offline T3sl4co1l
« Reply #52 on: February 26, 2016, 04:54:19 am »
I meant with the tube shown, sorry for using ambiguous pronouns  :-[
Offline SimonWasAnEngineer
« Reply #53 on: March 01, 2016, 07:54:02 pm »
I dont know why but vacuum tubes are really fascinating to me  ;D
@Artlav do you have a few more photos? And maybe the name?
I just checkt ebay, only the tube costs about 200€, a little bit to much for something that just sits on my desk and looks good  |O
This is technically a vacuum tube, for a cyclotron.  Does it count?   >:D
Relaxing to just sit and look at.  :)
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #54 on: March 01, 2016, 08:22:12 pm »
GMI-90, here is the full set of pictures:
http://lavart.livejournal.com/3340.html
The text is in Russian, but there isn't much to say.
And on the opposite side of the gas tube spectrum, here is a 2.5KW Xenon light in a box:
http://orbides.org/page.php?id=1003
Offline XOIIO
« Reply #55 on: March 01, 2016, 08:36:23 pm »
Hey, I got one of those! (though not in a box, and it's half a kilowatt lower than that one.)
I thought it was an x-ray tube of some kind, then found out what it was, and then found out (through here I think) that it's apparently under quite high pressure. Still haven't found a proper way to contain it.
Online wkb
« Reply #56 on: March 01, 2016, 08:47:13 pm »
Digital Equipment VAX9000 MCM (Multi Chip Module)
Offline ToeJam
« Reply #57 on: March 01, 2016, 11:00:32 pm »
I bet you get a great tan from that mercury rectifier!
Offline veedub565
« Reply #58 on: March 02, 2016, 02:01:16 pm »
Those old British film capacitors with the dipped color codes/bands.
I like them
Offline PointyOintment
  • ↑ I scanned my face
« Reply #59 on: March 02, 2016, 04:43:35 pm »
This is what I thought a FLUX CAPACITOR should look like.  Recognize this?
<attachment>
Some kind of wobbulator capacitor?
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
Offline dexters_lab
« Reply #60 on: March 02, 2016, 06:28:39 pm »
i think most would agree that the coolest components are anything made from glass, you can actually see or imagine the physics in action
hybrids on ceramic substrates come a close second though, this 8 pin hybrid i thought was quite cute
http://dexterslab2013.blogspot.co.uk/2015/10/teardown-lecroy-hvl100-discriminator.html
Offline Electric flower
  • Country: hr
« Reply #61 on: March 02, 2016, 08:12:42 pm »
I think that Kiel probes deserve place in this thread, especially when seen in action.
All work and no play makes Jack a dull boy.
All play and no work makes Jack a mere toy.
  • Country: hr
« Reply #62 on: March 02, 2016, 08:28:04 pm »
And this is pretty mental  ;D
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #63 on: March 03, 2016, 02:14:48 am »
That's interesting, the caps on the hybrid have what I have been led to believe is a piss-poor solder joint - there is no fillet at all.   Anyone know why that may be?
Have You Been Triggered Today?
Offline T3sl4co1l
« Reply #64 on: March 03, 2016, 10:59:42 am »
Not really, you just can't see it from this angle.  They may also use conductive epoxy versus solder (which if they did, might need to be pure lead solder so parts don't shift around during lid soldering (with solder or glass frit), and later board soldering steps).
I don't know if chip caps need to be tighter tolerance to fit on a hybrid, but most things are higher tolerance.  (The metal and glaze enamels are probably good examples of especially poor tolerances, as hybrids go.  This one looks to be screen printed for all layers.)  The semiconductors of course are a prime example, where nothing can be printed or etched nearly precisely enough to work directly, hence wire bonding is needed to make connections.
Offline calexanian
    • Alex-Tronix
« Reply #65 on: March 04, 2016, 04:19:52 am »
That is an E/M tube for schools to demonstrate how to calculate the mass of an electron. They used to build a different style one at M.U. there are several of them around down there to look at.
Charles Alexanian
Alex-Tronix Control Systems
Offline NiHaoMike
    • Facebook Page
« Reply #66 on: March 05, 2016, 03:02:37 am »
It's a "solid state motor start relay". Which turns out to add enough series resistance with the start cap to greatly reduce its effectiveness...
Online radar_macgyver
« Reply #67 on: March 05, 2016, 06:34:33 am »
Hydrogen thyratrons, the old-timey glass envelope kind. Specifically, the giant 1257.
Link to more info: http://home.earthlink.net/~webdisk1/oddtubes/oddtubes.htm
I tried to take a picture of one while it was running - it was with my crappy Nokia phone camera. They produce this weird purple glow. Luckily, we don't use them any more, replaced by slightly more modern ceramic envelope thyratrons
Edit: fixed link
« Last Edit: March 05, 2016, 06:36:27 am by radar_macgyver »
Offline dexters_lab
« Reply #68 on: March 05, 2016, 10:32:21 am »
doesn't look like solder in the traditional sense so maybe some conductive glue/epoxy, probably the same stuff that's glued down the other bits?
tighter crop attached
Offline mikron
« Reply #69 on: March 05, 2016, 11:43:46 am »
Looks like conductive silver adhesive.
Offline profany
  • Country: pt
« Reply #70 on: March 06, 2016, 06:58:20 pm »
resistance
 :D
Offline dannyf
« Reply #71 on: March 07, 2016, 11:59:40 am »
Glass passivated diodes. I have a few from way back.
