Author Topic: how to burn/damage PCB  (Read 759 times)
Offline strawberryTopic starter
  • Country: lv
« on: May 22, 2022, 02:36:05 pm »
soldering with 400C  :popcorn:
when tip is tarnished it wont take solder even with 400C and hot air wont help either
Offline jpanhalt
Re: how to burn/damage PCB
« Reply #1 on: May 22, 2022, 04:35:10 pm »
Weller seems to disagree: https://www.mouser.com/pdfdocs/WellerSoldering.pdf
Quote from: page 5
In order to raise the temperature of solder above it’s melting point, soldering tip temperatures are usually set between 700°F and 800°F.
I keep mine set at a smidgeon under 750°F (399°C).  The only time I have ruined a tip was when I accidently left it on overnight.
  • Country: lv
« Reply #2 on: May 22, 2022, 07:49:49 pm »
Quote from: page 3
Insufficient tinning when working with high temperatures over 665 F (350 C) and after work interruptions of more than one hour.
use 250 C for 60/40 and sensitive boards
pb free higher
soldering and desoldering is not the same
Offline langwadt
« Reply #3 on: May 22, 2022, 10:18:43 pm »
Quote from: page 3
pb free higher
250'C is far too low, everything will cooked to death before the solder melts
