> It can be a good idea to add series diodes to the outputs of each of the individual supplies, just to stop power flowing backwards into one of them, if they aren't designed to be paralleled.
I thought about this approach myself, but won't the 0.6-0.7V voltage drop caused by a silicon diode mean that you don't get the voltage level you want? Yeah, if you're willing to spend the big buxx, you can get ~0.1V drop germanium diodes, but even that may screw up your voltage significantly if you're running at 3.3V.
I figure if you want to parallel linear regs, you need to use adjustable regulators, and set them up so they feed Vcc + (diode drop) into the diode. Then it'll work like you expect. It's tempting to try and sense the voltage/current on the far side of the diode and feed it back to your adjustable reg, but I suspect that's gonna lead to problems with one regulator swamping the other...
Edit: And saturation beat me to it while I was writing this comment. Never mind!
