Author Topic: How mains hum is helping forensic scientists to fight crime  (Read 4118 times)
Offline ejeffrey
Re: How mains hum is helping forensic scientists to fight crime
« Reply #1 on: December 12, 2012, 09:00:45 pm »
It sounds like a great forensic technique for identifying a random recording, but not one that is terribly hard to fake if you know your forgery will be subjected to such analysis.
Online tom66
« Reply #2 on: December 12, 2012, 09:17:56 pm »
Very clever. Someone mentioned this at work today. But they got it the wrong way around with mains frequency. It goes up under greater supply than demand, down under greater demand than supply.
It would be hard to fake unless you had records of all of the mains frequency at the alleged time.
« Last Edit: December 12, 2012, 09:20:43 pm by tom66 »
Offline G7PSK
  • It is hot until proved not.
« Reply #3 on: December 12, 2012, 09:25:41 pm »
The frequency will go down on first meeting greater demand and when the demand cannot be met by increasing the field current the speed is wound up. I have seen the frequency vary between 49 and 51 HZ.
Offline aluck
  • Country: ru
« Reply #4 on: December 13, 2012, 03:01:01 am »
and you will manage to remove original frequencies...
I asked the guy I know from forensics lab. He said that it's a well-known and a widely-used method.
Offline ejeffrey
« Reply #5 on: December 13, 2012, 04:20:25 am »
Right, but that isn't exactly secret information, nor is it particularly hard to find after the fact.  Just find some other recording that takes place at the time you want to impersonate.
That is a potentially harder problem.  Like most forms of digital figerprinting, it is hard to do so without leaving any traces, but it all depends on how sophisticated the analysis is compared to how good the forgery is.  For sure a simple automated technique that uses a 2 Hz bandpass filter and a level crossing detector would be easy to fool.
As one tool in a suite of forgery detection tools I imagine it is useful, but it needs to be used carefully.
« Reply #6 on: December 13, 2012, 04:31:48 am »
How would it cope with highly compressed audio, which generally does a high pass of low frequencies to reduce bitrate.
Offline aluck
  • Country: ru
« Reply #7 on: December 13, 2012, 04:43:32 am »
It is not a universal method, nor that is the only one used. Also that method wouldn't work outside; 5-7 meters from a building and the 50/60 Hz signal is gone.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #8 on: December 13, 2012, 05:13:05 am »
Time to dig up Nixon and find out what happened to the missing 18 minutes.
iratus parum formica
