Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2381142 times)
Offline woody
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #4875 on: June 06, 2024, 12:20:08 pm »
Hello, this is my beginner hobby electronics room. I'm open to your suggestions.
Neat. Much neater than my own mess.
The one thing I would change? I would replace your current PCB holder with a Weller  ;D
Offline eutectique
« Reply #4876 on: June 06, 2024, 02:38:56 pm »
Fermenting lager at 20PSI/12C in fridge.
The source of spontaneous fermentation is clearly visible. ;)
Offline Howardlong
« Reply #4877 on: June 07, 2024, 12:17:07 pm »
Mend it Mark's new workshop.
The following users thanked this post: bookaboo, Edison
Offline David Hess
  • DavidH
« Reply #4878 on: June 07, 2024, 01:04:51 pm »
I am still unpacking after my move to New Hampshire.  I am cleaning and reorganizing my parts cabinets as I need them.
Online paulca
« Reply #4879 on: June 11, 2024, 09:50:11 am »
You mean the puddle of now beer syrup on the bottom of the old fridge?  That's just years of it being a keg serving fridge.  It's not intented to be sterile or even clean.  Doesn't need to be.  As long as what is inside the vessels is sane and anything that touches the inside of them.
It's unlike to ferment though :)  Not even wild yeast are that desperate.
I reused the yeast "trub" after using the pressure within the fermentor itself + the 19L keg tank at 20PSI to push the beer into the 12L keg.  Then I brewed a new 22L batch of lager last evening.  Opened the fermentor used my brand new BBQ tonqs w/sanitizer wash to lift the floating wifi hydrometer out to charge and clean and ...  pumped the new lager straight in.
Thing went off like a rocket.  No lag, no messing around, the cell count per litre was already so high it had hit 25PSI and completed a quarter of the ferment by morning.
The pressure fermentor has a 35PSI PRV!
Offline K0ELB
« Reply #4880 on: June 24, 2024, 03:31:44 am »
Moved last August to a new house with a finished basement and got the large room in the basement to myself, so I promptly set up a work bench and the ham shack. I became a Collins and Tektronix addict over the last couple of years.
Confirmed Tektronix Addict
The following users thanked this post: Smokey, Kjelt, Addicted2AnalogTek, Edison, BlownUpCapacitor
Offline K0ELB
« Reply #4881 on: June 24, 2024, 03:33:02 am »
A couple more:
The following users thanked this post: Smokey, Addicted2AnalogTek, Edison, BlownUpCapacitor
