Author Topic: Looking for a free public domain QR-Code geneator.  (Read 1360 times)
Online BrianHGTopic starter
« on: March 20, 2024, 08:35:33 pm »
Hi Everyone,
     I was just putting together a small company brochure.  I wanted to include a QR-Code in the bottom corner with a set email address & prefilled subject.
What good free public-domain QR-Code generator should I use?
Does a free one exist, or will I have to shell out money?
Offline John B
Re: Looking for a free public domain QR-Code geneator.
« Reply #1 on: March 20, 2024, 08:59:14 pm »
There's lots of them on linux, in the terminal or standalone programs. I think I even saw it somewhere integrated into the KDE desktop environment. There's a "generate QR code from selection" somewhere, I can't find it at the moment though.
Perhaps one of the developers also ports them to windows if that is what you need.
« Reply #2 on: March 20, 2024, 09:18:02 pm »
Yup, looking for a quick solution for windows...
Offline shapirus
  • Country: ua
« Reply #3 on: March 20, 2024, 09:22:27 pm »
They aren't public domain, mostly. Usually GPL or some other FOSS-compatible license.
However a program doesn't necessarily need to be public domain to permit commercial use.
Offline SiliconWizard
« Reply #4 on: March 20, 2024, 09:30:50 pm »
There are quite a few free online QR-Code generators. Do you specifically want to avoid them, say for confidentiality reasons?
This one is based on zint (open source: https://github.com/zint/zint ), should be buildable for Windows, but there are no direct binaries, so the online tool is your easiest path: https://www.barcode-generator.org/
They say there's no restriction as to commercial use.
The following users thanked this post: Someone, BrianHG
Offline tszaboo
« Reply #5 on: March 20, 2024, 10:05:14 pm »
Offline abeyer
« Reply #6 on: March 20, 2024, 11:13:11 pm »
Also built into chrome now: Right click any page and there's a Create QR Code for this page option. But you can type or paste any content into the popup that shows the code instead of the current url if you want.
The following users thanked this post: pdenisowski
Offline colorburst
« Reply #7 on: March 21, 2024, 01:12:48 am »
Seconded, zint is a fantastic tool. Windows builds can be downloaded from their sourceforge page: zint-2.13.0-win32.zip.
Offline Gribo
« Reply #8 on: March 21, 2024, 01:43:14 am »
If you can use a .NET library, There is Zxing. It can generate QR, Datamatrix and various linear barcodes.
I am available for freelance work.
Offline PeterH_1979
« Reply #10 on: March 21, 2024, 04:06:18 am »
Worked perfectly...
Offline mwb1100
« Reply #11 on: March 21, 2024, 05:33:48 am »
The free, GPL program qrencode is part of the libqrencode project.  For Windows users it has been ported to Windows (I don't know how well it works on Windows)
Since GPL came up as being distinct from public domain (which it indeed is), I think it should be noted that the GPL imposes *no* restrictions or obligations on users of GPLed software.  You can use it however you want, including commercially.
What the GPL does is restrict how you can distribute the software - if you distribute GPLed software (including if you incorporate GPLed code into your own program) then you must also provide a means for whoever you distribute the software to to also be able to get the source code for the software.
In summary - GPL restrictions only come into play when distributing GPLed software.
(note: there are uncommon exceptions when the output of a GPLed software contains text, images or audio that is embedded in the software itself)
« Last Edit: March 21, 2024, 05:43:10 am by mwb1100 »
Offline cosmicray
« Reply #12 on: March 21, 2024, 03:18:09 pm »
I am surprised that no one has mentioned the DDG search engine. Load a DDG basic window. Type in 'qr' followed by the URL you want a QR code for. It will respond with the desired qr code.
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
« Reply #13 on: April 30, 2024, 07:37:47 pm »
Here is a good functional online QR-Code generator with some custom controls and downloads as .png.
https://qrcode.tec-it.com/en/Raw
