Author Topic: OT: Any woodworkers here?  (Read 4081 times)
Offline Ground_Loop
Re: OT: Any woodworkers here?
« Reply #25 on: December 03, 2020, 02:42:01 am »
Or, apart from all the nuclear powered industrial options mentioned, you could just take a bit of time and use a cabinet scraper. I promise it will work just fine.
There's no point getting old if you don't have stories.
Online madires
  • A qualified hobbyist ;)
« Reply #26 on: December 03, 2020, 10:48:00 am »
yea no this would require an auto planer you would probobly kill yourself because you need to resharpen it so often, which is why I suggest mailing it out. That blade is not going to live long doing that cut.
I don't know what types of hand planers you can get at your local home improvement store and which quality they are, but a cutting edge becomes dull for a hand planer as well for a big heavy professional planing machine with 3-phase motor. Some wood types can be quite demanding. Either you apply some elbow grease or pay someone else for doing that. ;)
Offline Refrigerator
  • Country: lt
« Reply #27 on: December 03, 2020, 01:11:48 pm »
Planing isn't hard, just that there's a high risk of tearout when cutting endgrain.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Online coppercone2
« Reply #28 on: December 03, 2020, 05:04:57 pm »
the factory does so much it does not care about 1 extra and they have all the tooling in place to keep their production running quickly
but again, I would just sand it. Its worth doing something because they are alot of work to make.
« Last Edit: December 03, 2020, 05:07:26 pm by coppercone2 »
Offline CatalinaWOW
« Reply #29 on: December 03, 2020, 06:35:51 pm »
Planing will work, but the end grain work requires a good plane iron, extremely sharp and perfectly adjusted in the plane to make it anything other than a wretched chore.  If you aren't experienced it may not be a good route to take.
Since this task requires a multi-hobby/interest approach you might check if you or a friend has a mill.  Something that goes through aluminum/steel laughs at end grain.  You could have a surface ready for finish sanding in an hour or less including setup.  If you go out to a shop to do this your biggest issue will be being sure they don't contaminate your block with coolant, machine oil and other nasties.
« Reply #30 on: December 03, 2020, 08:10:11 pm »
However, you will likely still have the same problems with tear-out as you would have with a plane. This is a consequence of wood being an anisotropic material. The solution for a mill would be the same as with a plane, make sure that the edges are supported by being clamped with some sacrificial scrap.
It occurs to me that a fly cutter is probably the best tool for the job, and that's something one can often get away with using on wood in a drill press. The cutting forces on a single point tool like a fly cutter are relatively low compared to an end mill or face mill. I'd still be concerned about tear-out but that can be ameliorated as above. If one had a drill press to try this on, the next question would be "Do I have enough space over the bed to swing a fly cutter far enough to be useful?".
« Reply #31 on: December 03, 2020, 08:42:12 pm »
Surface finish is relative to tool tip speed and feed rate. Period.
An experienced operator could get a perfect finish on this board with a mill.
Offline CatalinaWOW
« Reply #32 on: December 03, 2020, 08:51:16 pm »
I agree, tear out at the edges could be a problem.  But either sacrificial material at the edges as you suggest or a well chosen tool path will eliminate the issue.
« Reply #33 on: December 03, 2020, 09:32:45 pm »
Tear-out in this context has nothing to do with surface finish but with the chunks breaking off the edges.
Offline langwadt
« Reply #34 on: December 03, 2020, 09:36:51 pm »
yep going around the edge so the cutting is always inwards also works on metal to avoid making burr
Offline Alex EisenhutTopic starter
  • Place text here.
« Reply #35 on: December 04, 2020, 07:02:16 pm »
Cool, I found my hobby plane, I'll start this afternoon and let you know in a couple of months how far I get.  :=\
Online madires
« Reply #36 on: December 04, 2020, 07:07:35 pm »
Ouch! :scared:
« Reply #37 on: December 04, 2020, 07:38:25 pm »
:-DD
Like pissing into the wind !  :box:
Get the grinder and sanding pads out if you require real progress.
Online coppercone2
« Reply #38 on: December 04, 2020, 07:49:39 pm »
don't use the grinder on wood, its too easy to burn it and get black / charcoal spots. You just don't need those kinds of RPMs.  Same with flapwheel I think unless you are very careful doing touch up.
« Reply #39 on: December 04, 2020, 07:56:23 pm »
Balderdash !  :bullshit:
Stripped the paint off my old house with 5" and 7" sanding pads and smoothed with a rotary orbital and 40 grit.
9" grinder for the large areas and the 5" for the more delicate/confined areas.
Until you've done it you couldn't know.  ;)
Online coppercone2
« Reply #40 on: December 04, 2020, 07:59:46 pm »
I like to strip paint with a 20? grit carbide oscillating tool for a garage door.
When I tried flap wheels on a grinder on wood I got horrible results. Maybe if you use the silicon carbide abrasives it might work better (the ones for aluminum)
« Reply #41 on: December 04, 2020, 08:39:50 pm »
They weren't coarse enough. If you spin too fine grit fast they will clog, guaranteed.
If you need remove any material you need a 24 grit sanding disc on a grinder with a rubber pad.
Velcro backed ones......yeah, nah as they're only good for low rotational speeds like rotary orbital sanders.
Stuff like these that I linked before works:
Offline Mr. Scram
  • Display aficionado
« Reply #42 on: December 06, 2020, 09:46:03 pm »
Planing is quite drastic and there's a fair chance it's not required. Cutting board maintenance also deals with occasionally stripping down a board a starting fresh. Planing it isn't very usual. If you insist on planing that's also how you get the gunk off. There's a world of resources dedicated to the subject.
https://www.knivesandtools.com/en/ct/how-do-you-maintain-a-wooden-cutting-board.htm
