Author Topic: How do world citizens store their resistors? Not SMD types.  (Read 6654 times)
Offline ez24Topic starter
  • L.D.A.
« on: February 08, 2018, 05:28:32 am »
Hi
The reason I put US in the title is because I live in the US and I am looking for resistor storage solutions I can buy in the US.
I would like reasonably priced plastic boxes.
thanks
Edit:  Here is the same topic from 2016
https://www.eevblog.com/forum/chat/how-do-you-store-your-resistors/msg1053220/#msg1053220
« Last Edit: February 09, 2018, 05:58:26 am by ez24 »
Offline tpowell1830
  • Peacefully retired from industry, active in life
Re: How do US citizens store their resistors? Not SMD types.
« Reply #1 on: February 08, 2018, 05:42:08 am »
I use the snack size zip lock bags, and a shoe box. I mark values on bags with sharpie.
PEACE===>T
The following users thanked this post: ez24
Offline Melt-O-Tronic
  • Brilliant with a slaughtering iron in my hand!
« Reply #2 on: February 08, 2018, 05:56:43 am »
I use these.  They snap together nicely and the green & pink ones are just the right length for new 1/4 watt through-hole resistors.
https://www.adafruit.com/product/433
https://www.adafruit.com/product/432
Offline xmo
« Reply #3 on: February 08, 2018, 06:03:05 am »
I store them in plastic drawers with a label on each drawer showing the standard value.
Online TheSteve
  • Living the Dream
« Reply #4 on: February 08, 2018, 06:10:48 am »
I want your containers with the "Batwings" on them!
VE7FM
  • L.D.A.
« Reply #5 on: February 08, 2018, 06:33:28 am »
Looking at these are called "component boxes".  So searching on Aliexpress (easy to buy from the US) I see this:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=AS_20180207212548&SearchText=component+box
A lot to study  :-+
  • L.D.A.
« Reply #6 on: February 08, 2018, 06:34:30 am »
Holy crap  :phew:
Offline Ampera
    • Ampera's Forums
« Reply #7 on: February 08, 2018, 07:06:14 am »
Can you find a M68k within that collection in under 20 seconds?
If not, you aren't collecting right.  :-+
Since they are so cheap, in China we just buy them in full ammo packs, and use the original paper box to store them.
I've never heard those things called ammo packs, but now that I look at them they look like something you would load into a machine gun.
Maybe we could invent a gun that cuts, bends, and places resistors in a hole within a split second. Would serve about 0 purposes as real pick and place machines are used for anything that requires any sort of speed, but it would be damn cool.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Online TheSteve
  • Living the Dream
« Reply #8 on: February 08, 2018, 07:35:22 am »
That existed for many years, the through-hole pick and place machine. Probably not too many in use today. The "ammo pack" term is still quite common for through-hole components though.
VE7FM
« Reply #9 on: February 08, 2018, 09:03:18 am »
There was another thread on this some time back:
Offline tooki
« Reply #10 on: February 08, 2018, 09:20:22 am »
Hi
thanks
Title fail! :p I’m a US citizen, but live in Europe!  Foreigners living in USA might have a better answer! ;)
The following users thanked this post: voltsandjolts, ez24
Offline Zero999
  • 0999
« Reply #11 on: February 08, 2018, 11:56:37 am »
I store them in cases I got from work awhile ago, when they were having a clear out.
Offline andtfoot
« Reply #12 on: February 08, 2018, 12:15:32 pm »
I do similar, but then use a hole punch above the seal to put them in ring binder books in order of value; makes it pretty easy to find stuff.
I only keep about 10 of each value (up to maybe 50 or so) so not sure how it would go for larger collections.
Offline MT
  • Country: aq
« Reply #13 on: February 08, 2018, 12:31:34 pm »
A lot to study  :-+
https://www.aliexpress.com/item/1PC-New-15-Slots-Cells-Portable-Jewelry-Tool-Box-Container-Ring-Electronic-Parts-Screw-Beads-Component/32820166282.html?
Heey, those transparent boxes i have a bunch of, nice and airtight , i paid 1 euro per box . Tight enough to store 0603 without creeping away. I store some recycled IC's wrapped in alufoil in them to, looking for graphene i a spraycan to improve the box.
I have tested this, not good difficult to open lids, not air tight 0603 can fall out, sold here as medicare box for pills.
https://www.aliexpress.com/item/DIY-tool-Box-Electronic-plastic-toolbox-powdered-alcohol-Casket-SMD-SMT-screw-component-storage-box/32497849147.html
« Last Edit: February 08, 2018, 04:29:45 pm by MT »
Offline xmo
« Reply #14 on: February 08, 2018, 02:08:01 pm »
TwoOfFive wrote: "...Can you find a M68k within that collection in under 20 seconds? ..."
I believe I could.  Or a 6809, or a 6800, or an HC11.  I even have an original 8008 I never got around to using.
The parts tubes with the Motorola logo are from long ago.  Back in the day, Motorola sold the blue parts tube racks to their two-way service shops.  The offered packages with a rack which came filled with parts or hardware in the tubes.  When you used up the contents of a tube, you re-ordered and got a new tube.  You could also buy empties.  Later, the tubes they supplied changed and the caps have no logo.  Sometimes these show up on ebay.
Here is another more inclusive view of my parts and component storage.
The following users thanked this post: xrunner, Ampera, sokoloff
Offline cdev
« Reply #15 on: February 08, 2018, 02:15:09 pm »
This would be an almost ideal solution for me if only they were cheaper.
Offline elecman14
« Reply #16 on: February 08, 2018, 02:22:12 pm »
If they are ammo packed (still on the strip) around qty. 100 of them will fit per compartment in a plano 3500 "tackle" box. They would fit loose as well if trimmed.
Offline alsetalokin4017
« Reply #17 on: February 08, 2018, 03:24:38 pm »
What, me worry?
 >:D
The following users thanked this post: NivagSwerdna
  • L.D.A.
« Reply #18 on: February 08, 2018, 05:51:03 pm »
Added this to my first post.  What is new to me is tubes.
  • L.D.A.
« Reply #19 on: February 08, 2018, 06:03:33 pm »
These are 70 cents each  vs 3.00 each (I do not know which price you are looking at)
https://www.aliexpress.com/item/10-Pcs-Set-Portable-Electronic-component-Storage-box-IC-parts-box-paster-box-screw-small-object/32840887309.html
There are three methods I am going to try.  The above box.  Small zip lock bags.  Tubes
Online TheSteve
  • Living the Dream
« Reply #20 on: February 08, 2018, 09:09:26 pm »
If you ever feel the need to get rid of the Motorola marked tubes do let me know. I'd like some as would my friend who owns batlabs.com
VE7FM
  • L.D.A.
« Reply #21 on: February 08, 2018, 10:30:06 pm »
From the other post, this is the first thing I am going to try (No.6 coin envelopes)
https://smile.amazon.com/Quality-Park-Envelopes-6-Inches-50662/dp/B0012VIB0C/ref=sr_1_3?ie=UTF8&qid=1518126069&sr=8-3&keywords=coin+envelopes+6
Heck of a lot of them  :scared:
These will fit in Dollar Tree's plastic shoe boxes that they sell for $1.00 each.  Got 96 of them suckers.
https://www.dollartree.com/Essentials-Colorful-Translucent-Plastic-Storage-Boxes-with-Lids/p357592/index.pro
I got 48 in clear and 48 in assorted colors and in the store you can buy any amount.  But they are not always in stock.
« Reply #22 on: February 09, 2018, 03:09:10 am »
Nice find!  I may pick up some more on Aliexpress.  I got mine from Sparkfun, but they're carrying fewer sizes now.
They are called Wen Tai boxes.
You don't need a whole lot of them for a basic assortment of resistors either.  This is what I keep handy at the bench for breadboarding.  It covers most of the E12 values, plus extra boxes for 10K and 330R, which I use a lot.
Offline BradC
« Reply #23 on: February 09, 2018, 03:54:49 am »
Not a US citizen.
Offline PlainName
  • Country: va
« Reply #24 on: February 09, 2018, 05:32:52 am »
How do you get the text on the boxes? On the right they are obviously labels, but on the pink/green ones the text has no background.
