Author Topic: Starship is now Stacked  (Read 4077 times)
Offline David Hess
  • DavidH
Re: Starship is now Stacked
« Reply #25 on: August 11, 2021, 04:08:48 am »
They have already flow the falcon heavy with 27 merlin engines split across 3 cores.  29 larger engines on a single core is obviously a different situation but I think comparing to a 60 year old soviet rocket with a host of other issues and limitations is probably not very relevant either.
But other rockets displayed problems not evident when testing fewer engines, like pogo oscillation.
Offline iMo
  • Country: cv
« Reply #26 on: August 11, 2021, 07:16:20 am »
Sure, we cannot compare the rocket technology of that time, but at least they had similar launch towers (1969)  :D :D
More on its 30 engines issues on
https://www.popsci.com/this-rocket-failed-to-put-soviets-on-moon/
http://www.russianspaceweb.com/n1_5l.html
« Last Edit: August 11, 2021, 07:38:11 am by imo »
Offline mrflibble
« Reply #27 on: September 01, 2021, 07:37:44 am »
Some time ago there was mention of maybe doing a static fire of 9 engines first. Not sure what the current status of that plan is...
This one: "Depending on progress with Booster 4, we might try a 9 engine firing on Booster 3"
https://twitter.com/elonmusk/status/1417277335863140363
