In my project I need to transfer some heat ( about 50°C) from a plain( straight) metal heating element ( approximately 100mm x 200mm of size) to a glass of a similar size. The problem is that the glass need not be precisely straight and the heat is NOT transfered evenly. Is there any material (being between the heating element and the glass) that flattens the unevenness( between the heat element and the glass) so that the heat is transfered evenly?
