Author Topic: HDMI over tcpip (not a booster)  (Read 12053 times)
Offline Someone
    • send complaints here
Re: HDMI over tcpip (not a booster)
« Reply #25 on: October 24, 2015, 11:17:13 pm »
So why on earth does anyone use HDMI (except for the reason that it's included in almost all consumer products). SDI is clearly a far better solution. Reminds me of the VHS v Betamax or HD-DVD v Blu Ray wars. The better technology is pushed to the sidelines merely because of popularity and marketing.
HDMI has a return path and is cheaper to implement since the transceiver rates are lower (though the aggregate is higher), but it has also been ahead of the curve in aggregate bandwidth with the SDI standards still not final on 6Gbit/s or 12Gbits/s while HDMI has had those rates for 5 and 2 years now. Or consider that SDI has no copy protection or encryption on it while HDMI "asserts" "rights" ;)
Online NiHaoMike
    • Facebook Page
« Reply #26 on: October 25, 2015, 12:37:04 am »
What about Displayport?
Offline andtfoot
« Reply #27 on: October 25, 2015, 12:59:13 am »
HDMI had a few years head-start on DisplayPort I think.
Offline BradC
« Reply #28 on: October 25, 2015, 06:28:22 am »
you "slightly" overpaid
http://www.ebay.com/itm/330ft-100M-HDMI-Extender-Over-TCP-IP-Convert-Ethernet-Lan-Only-Receiver-IR-/311384903083
True, but then I got them off the shelf, same day and with warranty. I also don't pay list price, but yes they were considerably more expensive than the E-bay price.
this product is the exact same thing reverse engineered by Daniel and covered on hackaday: http://hackaday.com/2014/01/25/reverse-engineering-an-hdmi-extender/
Nice, thanks for the link.
Offline crispy_tofu
« Reply #29 on: October 25, 2015, 09:41:42 am »
Yep, HDMI was designed in December 2002, while DisplayPort was designed in May 2006 (and started production in 2008).  ;D
Offline Smokey
  • Not An Expert
« Reply #30 on: November 05, 2017, 05:49:26 am »
It's national revive a dead thread day!
I'm looking to do something like this and I came across these two devices:
$261 = H.265 = FBE200-H.265 = https://www.amazon.com/Encoder-Streaming-MPEG-4-Youtube-Converter/dp/B01NCP0JNU
$160 = H.264 = FBE200-H.264 = https://www.amazon.com/Encoder-Broadcast-Facebook-Streaming-Platforms/dp/B01N4PJDX2
http://www.fmuser.com/html/productlist/list-146-1.html
Not a lot of info about these guys, but the specs look good. It looks like a totally reasonably priced all in one solution.
My question now is:
Do I care about H.265 vs H.264 here?  Since this is a bandwidth intensive thing and I'm hoping to stream over the internet, will the better compression make a noticeable difference?  Is it worth another $100?
Offline Kjelt
« Reply #31 on: November 05, 2017, 10:22:39 am »
You need 265 to do 4k for 1080p 264 suffices.
Offline Smokey
  • Not An Expert
« Reply #32 on: November 06, 2017, 10:21:29 pm »
I don't really plan on doing anything with 4K, but if the 265 is significantly more efficient at the same resolutions then it would lower the bandwidth required and be a much more attractive.
I was talking with a non-tech type friend about this and he says "so you mean like a slingbox?"
Not sure how I didn't know about this.
http://www.slingbox.com
Online Monkeh
« Reply #33 on: November 06, 2017, 10:31:16 pm »
« Last Edit: November 06, 2017, 10:32:55 pm by Monkeh »
Offline Richard Crowley
  • KJ7YLK
« Reply #34 on: November 06, 2017, 10:37:33 pm »
If the question is more generally HD video over TCP-IP, a vendor has developed and released to open-source what looks like a promising protocol:
https://www.newtek.com/ndi/
Online Monkeh
« Reply #35 on: November 06, 2017, 10:38:59 pm »
Because we don't already have five competing standards.
Offline Smokey
  • Not An Expert
« Reply #36 on: November 06, 2017, 11:48:56 pm »
Obligatory XKCD link = https://xkcd.com/927/
