If the originals were 10 - 68uF and the voltage is 200 - 350V and they physically will fit in the position then yes. They will be higher ripple rated and will run cooler than the originals.
Only caveat is if the supply has Selenium rectifier stacks or valve rectifiers, then you will need to place a series resistor in the lead from the rectifier to the capacitor, generally something in the order of 10-22R 5W, current depending, to reduce the ripple current through the rectifier to a lower level. These old rectifiers rely on the capacitor being a high resistance to limit the current to a safe level, so then you need extra resistance with the modern low ESR unit. Only needed on the first capacitor, as then you will find that further on there is sufficient series choke or resistance built in to the circuit.
