Author Topic: The EEVblog Bunker  (Read 19616 times)
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: The EEVblog Bunker
« Reply #25 on: December 02, 2014, 06:32:19 pm »
and after a year you might want to give another coat.
...By which time there will be so much stuff on the floor that even the thought of clearing it to re-coat means it won't happen
Day Job: Mostly LEDs
« Reply #26 on: December 02, 2014, 06:48:14 pm »
Then you just do the visible parts, as the covered side will still be fine.
Offline TerraHertz
    • It's not really a Blog
« Reply #27 on: December 07, 2014, 02:51:06 am »
A good fix for echo, is to find some old carpet (free) and hang it on the walls. Before you put shelves up.
Online David_AVD
« Reply #28 on: December 07, 2014, 02:59:39 am »
Painting the block walls will increase the echo.
Offline Monkeh
« Reply #29 on: December 07, 2014, 03:20:52 am »
But decrease the dust.
Offline Whales
    • Halestrom
« Reply #30 on: December 07, 2014, 05:41:02 am »
No ventilation is going to be a pain in the long term.  Even if you don't have moisture problems, it won't smell nice or be fresh.  You can imagine the look on Sagan's face when he's told he has to visit daddy in the fart chamber again.
Can you poke a hole through the besa blocks to the outside world and install a low-speed mains fan?  If the owners don't like it, tell them it's for ducting your air con, but you've found a way to do it without having to bother them with the outside unit  ;)
Have you tried finding out who operates the system for the ducts on your ceiling?  Who knows, they might not mind if you ask about 9mm'ing some holes in it.
« Reply #31 on: December 07, 2014, 06:27:49 am »
Look for old curtains and hang on the wall so you can just close them over the wall when needed for recording. Cheap and you only have to look at them when recording, otherwise they are out of the way. Lined ones you just hang with the lining facing inwards and look at unbleached linen.
Offline pickle9000
« Reply #32 on: December 19, 2014, 07:20:43 pm »
Things to do with old doors,
- Bench tops (handle holes at the back for cable feed through).
- Slide for Sagan. Also good for car toy races.
- Corner box for packing materials.
- Just sit them on the floor to stack stuff on, keeps stuff off the cement. Bubble wrap helps between cement and door.
- Make a couple EEVblog signs and just keep moving them from place to place.
- Train set table.
- Get a couple saw horses and make a tear down bench for the really nasty stuff, flip over when destroyed.
Offline Monkeh
« Reply #33 on: December 19, 2014, 07:33:53 pm »
The stuff running down the walls is just slurry from the roof slab. Worked its way past the shuttering. Pretty normal, usually it's hidden above drop ceilings.
« Reply #34 on: December 21, 2014, 09:06:34 am »
That though is pretty neat brickwork, all lines even, all blocks fully seated and all joints are levelled off. Takes skill to do that, especially on an unplastered wall. Paining though will be an issue, you need a rough surface roller, and at least 3 coats to get a coat that will not show all than the worst imperfections, or learn how to bag wash the wall to get a plaster layer over them to make a smoother surface.
Here though those walls would be put in after shuttering and casting the floor slab above, not as part of the support structure during casting, along with it being a load bearing structure.
Offline EEVblogTopic starter
« Reply #35 on: December 21, 2014, 10:55:38 am »
I was wrong, it has excellent ventilation. That ducting comes directly form the outside and is dedicated to my unit and unit next door. The fan turns on automatically when I switch the lights on, and pumps fresh air from outside into the lab, not out as I had assumed.
In theory, fresher air than my lab.
« Reply #36 on: December 21, 2014, 10:57:00 am »
Probably worth sealing the floor to reduce dust before you fill it with crap.
Yes, I plan on doing that.
Offline nowlan
« Reply #37 on: December 21, 2014, 11:06:34 am »
fan drawing air would play havoc for temperature, summer/winter.
« Reply #38 on: December 21, 2014, 11:20:31 am »
I'd rather have the fresh air thanks.
But in any case, no it shouldn't. 30m or so of internal ducting will take care of most air temp differential by the time it gets there. And then the volume is so low that it won't make any huge difference. I've done these sorts of measurements on my solar air heater design.
« Last Edit: December 21, 2014, 11:23:21 am by EEVblog »
