here's the quick arbexpress <-> ultrawave converter, based on BAW info. report if any error or if its working with your DG1022... i put default values in the bottom tags (and top's Quantify & Wave), so i think you should edit those to fit your need, except Amplitude, the converter will automatically calculate based on max magnitude found the data set, thats the best guess i think.
