Author Topic: Has anyone ever seen this DMM?  (Read 5623 times)
Offline SoftwareSamuraiTopic starter
« on: October 29, 2012, 01:59:49 pm »
The DM620 "Data Logging Meter" from Circuit Specialists.
Does anyone actually have it and care to post a review?
Offline Lightages
  • Canadian po
Re: Has anyone ever seen this DMM?
« Reply #1 on: October 29, 2012, 04:03:01 pm »
I cannot say anything other than it appears to be another too good to be true meters. From the fuse replacement diagram it appears to be using small fuses instead of the big HRC ones. They could still be rated the the correct voltage but who knows.
It certainly looks like an interesting meter otherwise. The lack of selection dial for function selection seems a bit of a pain. But if it meets its specifications and has reasonable safety it could be a great buy.
Offline Lightages
  • Canadian po
« Reply #2 on: October 29, 2012, 04:11:33 pm »
I just a quick search for DM620 and it looks like a cheap rebadge for many companies. harry66 on this forum mentions it in a bad light. I would avoid it.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: October 29, 2012, 05:08:37 pm »
It may seem a nuisance, but the User's Manual is a poor scan of a printed manual..
I don't know any serious manufacturer that does not have the source documentation of their own product (thus generating a true PDF).
Also, the page says Manufactured in Korea by SMTECH. That is probably the ODM.
As mentioned by Lightages, if you are looking for a data logger and will never use this in high voltages that could work. However, In my opinion I would probably save a bit more and bet in something from a more reputable brand (EX540 from Extech, for example).
« Reply #4 on: October 29, 2012, 06:11:03 pm »
Thanks for the info guys.
I was curious because that's the first time I'd seen a DMM with that type of display.
Offline arekm
« Reply #5 on: October 29, 2012, 06:58:09 pm »
Offline T4P
  • Country: sg
    • T4P
« Reply #6 on: October 30, 2012, 04:03:44 pm »
I assume you haven't see the Fluke 287/289?
« Reply #7 on: October 30, 2012, 05:07:16 pm »
You assume correct! Nice DMM, but a bit pricey.
Offline T4P
  • Country: sg
    • T4P
« Reply #8 on: October 31, 2012, 03:09:02 am »
It's a fluke after all.  ;D
Dot Matrix displays are easy to implement but they have ghosting delays of several years ... plus a contrast ratio of 0 (essentially)
Check out the U125XB series from agilent, OLEDs  ;)
http://www.home.agilent.com/agilent/product.jspx?cc=SG&lc=eng&nid=-33167.920237&&cc=SG&lc=eng
http://www.home.agilent.com/en/pd-1766293-pn-U1252B/handheld-digital-multimeter-45-digit?nid=-34618.920238&cc=SG&lc=eng 7seg version
Man why dont we have color IPS screens on meters ... Throw in touchscreen to configure the meter but not replace the buttons
