Author Topic: GFCIs and Treadmills  (Read 1740 times)
Offline thm_w
  • Non-expert
Re: GFCIs and Treadmills
« Reply #25 on: May 02, 2024, 10:04:29 pm »
Didn't realize GFCI was required in the garage already, "GFCI receptacles are required in bathrooms, garages, crawl spaces, basements, laundry rooms and areas where a water source is present." Definitely only on newer builds?
I thought that UL and IEC standards specify a maximum of 0.5 mA of earth leakage current for corded appliances (except heating/cooking appliances which are allowed a bit more).
If such a device had leakage high enough to trip a GFCI, surely it would be non-compliant with the relevant standards?
I would assume this treadmill is allowed 3.5mA, as its a grounded appliance.
https://slpower.com/App-slpower/images/whitepapers/An113%20Leakage%20Current.pdf
https://electrical.theiet.org/wiring-matters/years/2021/85-may-2021/back-to-the-forum-earth-leakage/
« Last Edit: May 02, 2024, 10:06:44 pm by thm_w »
Offline m k
« Reply #26 on: May 04, 2024, 08:09:00 am »
When she runs an extension cord into the house and plugs it into a non-GCFI circuit, the treadmill works fine.
Extension cord from one area to the other is a no-no.
There is a safety barrier between areas.
Don't break it.
Hey, what can I say? She's a software engineer.  :-//
If PE is connected through and through the hole in a barrier is much smaller.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
