"The fact that something has temperature is a reflection of the idea that it interacts with stuff around it," Sudhir says. "And it's harder to isolate larger objects from all the things happening around them."
The transmitting antennas operated at frequencies from 200 megahertz to 10 gigahertz [...]. The receiver consisted of two antennas connected to a signal digitizer. The digitized data were transferred to a laptop computer and uploaded to the graphics processing unit to reconstruct the images.The NIST team used the method to reconstruct a scene with 1.5 billion samples per second, a corresponding image frame rate of 366 kilohertz (frames per second). [...]With 12 antennas, the NIST system generated 4096-pixel images, with a resolution of about 10 centimeters across a 10-meter scene.
I can't see a problem here.The topic is saying "Fun for nerds". So, if someone here is finding this interesting (and having therefore a bit fun), then I'd call it on-topic.
