Author Topic: Forum clock has changed time?  (Read 3950 times)
Offline BrianHGTopic starter
« on: August 16, 2019, 05:02:49 am »
Has anyone else seen their forum clock move backwards an hour just recently?
Is this permanent?
Offline EEVblog
Re: Forum clock has changed time?
« Reply #1 on: August 16, 2019, 05:21:03 am »
IIRC I changed the server tiem last week because it was set to Melbourne time
The following users thanked this post: BrianHG
Offline wilfred
« Reply #2 on: August 16, 2019, 05:36:15 am »
What time is it set to now?
Offline wilfred
« Reply #3 on: August 16, 2019, 05:37:40 am »
Because it is 15:37 now in Melbourne.
« Reply #4 on: August 16, 2019, 05:51:47 am »
The forum tells you your set time at the top left of the web page where it says:
Hello [USER_NAME]
Show unread posts since last visit.
Show new replies to your posts.
August 16, 2019, 01:50:28 am
Offline wilfred
« Reply #5 on: August 16, 2019, 07:55:59 am »
I'm just saying nothing seems to have changed for me and Sydney and Melbourne are the same time zone.
Offline Tom45
« Reply #6 on: August 16, 2019, 02:24:15 pm »
Is this permanent?
Has to do with summer vs. winter time in the two hemispheres. There are 4 different time offsets because of when the time switch over occurs differs between down under vs. here.
Click on Profile and then just above where it says Summary, move your mouse over Modify Profile (it's a button even though it doesn't look like it) and choose Look and Layout.
The Time Offset in use is shown. It's -17 for me right now. Click the auto detect and it will be correctly set for you.
This procedure is necessary 4 times per year to keep the forum time accurate for those of us in the northern hemisphere.
Offline wilfred
« Reply #7 on: August 17, 2019, 01:07:58 am »
This is not the time of year the daylight savings time is changed in Australia. No Queensland forum members, a state that does not observe DS time, have reported changes.
If you're correct in suggesting 4 changes per year are necessary for some members then that is just a good reason to set the servers to UTC. Surely that would have arisen as an issue by now.
There must be another explanation.
https://www.australia.gov.au/about-australia/facts-and-figures/time-zones-and-daylight-saving
Offline TheSteve
  • Living the Dream
« Reply #8 on: August 17, 2019, 01:26:10 am »
+1 vote for the base time to be UTC.
VE7FM
The following users thanked this post: Ian.M, Tom45, guenthert, BrianHG
Offline EEVblog
« Reply #9 on: August 17, 2019, 02:30:00 am »
Both myself and gnif (who does all the server admin) are both in Sydney time zone  :P
Online Monkeh
« Reply #10 on: August 17, 2019, 03:00:05 am »
I've asked for this before, but it seems one or two people (however important they may be..) not having to change their forum settings or do a little mental math outweighs the majority of the forum needing to alter their offset four times a year.
Really SMF should be able to deal with it, but it doesn't.
Offline Tom45
« Reply #11 on: August 17, 2019, 04:34:11 am »
This is not the time of year the daylight savings time is changed in Australia.  ...
My personal experience is that I can go quite a long time before noticing that the forum time disagrees  by an integer number of hours with my local time. For example only about a month or two ago I noticed, and corrected for, the time changes that took place in March and April.
To be right on top of it, the 4 changes are:
Second Sunday in March North America switches to summer time
First Sunday in April, Australia switches to winter time
First Sunday in October, Australia switches to summer time.
First Sunday in November, North America switches to winter time
I used to do quite a bit of business with customers in New Zealand and had to keep up with each transition so that meetings and phone calls took place at the proper times. Now I have the luxury of being able to mostly ignore it.
Offline wilfred
« Reply #12 on: August 17, 2019, 04:47:51 am »
Don't you have to change the servers times twice a year now anyway?
Offline EEVblog
« Reply #13 on: August 17, 2019, 06:40:47 am »
Don't think I've ever bothered actually.
Offline TheSteve
  • Living the Dream
« Reply #14 on: August 17, 2019, 07:39:46 am »
Your forum - your rules.
Although it would benefit roughly 50000 other users.
VE7FM
Online Monkeh
« Reply #15 on: August 17, 2019, 01:12:03 pm »
No, you wouldn't have to - it's set to your timezone, including DST changes. Which makes everyone else do it four times a year.
Online tooki
« Reply #16 on: August 19, 2019, 11:06:13 am »
What kind of stupid forum software doesn’t just use UTC internally and then convert it to local time on display?! That’s basically how every OS does things now...
The following users thanked this post: Tom45
Offline EEVblog
« Reply #17 on: August 20, 2019, 10:57:14 am »
Happy now?
The following users thanked this post: cs.dk, Ian.M, TheSteve, BrianHG
Offline StillTrying
  • Country: Broken Britain
« Reply #18 on: August 20, 2019, 11:49:28 am »
The am/pm is the wrong way around for me!
Local Time: August 20, 2019, 12:47:43 am
edit:
Fixed it by setting Time Offset: 1   auto detect set it to -11.
August 20, 2019, 12:56:20 pm
« Last Edit: August 20, 2019, 12:00:36 pm by StillTrying »
Offline soldar
« Reply #19 on: August 20, 2019, 12:01:26 pm »
I never check the forum time but now that I check something definitely ain't right. Forum indicated time: 4 AM, my time: 2 PM. 10 hrs difference.
Offline EEVblog
« Reply #20 on: August 20, 2019, 12:08:52 pm »
You have to set a time offset from UTC in your profile
Offline soldar
« Reply #21 on: August 20, 2019, 12:36:12 pm »
OK. Done. Although I believe I was showing the correct time before this change so I am not sure it is related to UTC, server time or what. And if I may have to change it manually when winter time kicks in again.
If I had the correct time before I should continue to have the right time now because my time zone has not changed. I assume even if the server's time zone is changed that does not affect anything because timestamps would include deviation from UTC.
Not that it is of any major importance.
I have had big problems with my home security camera systems on this account. The cameras seemed to change their time randomly adding an hour here and there and I finally just put the entire system on UTC. Then once I had to explain to the police why the time stamp on the video was two hours off local civil time. The guy was not sure and we had to check sunrise to see the "real" time.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #22 on: August 20, 2019, 02:31:48 pm »
I'm in Melbourne where the forums clock was originally set to which meant that the time was always correct regardless of whether I was logged in or not. With the change to UTC the forums time now shows that it is currently ten hours behind so the +10 offset is only applied when I am logged in, as I mostly read the forum as a guest or signed out this is now horrible. Is this what people elsewhere experienced prior to the change or am I missing something ?.
Offline StillTrying
« Reply #23 on: August 20, 2019, 02:49:13 pm »
Yes, that's what is was like around here, half a day difference between logged in/out. It's only 1 hour (BST) difference here now between logged in/out . :)
  • Cursed: 679 times
« Reply #24 on: August 20, 2019, 03:03:55 pm »
Bugger, I liked it the way it was before but if it benefits others elsewhere then so be it. Being ten hours in front puts us in a different day so keeping track of new posts whilst signed out is going to be tricky from now on.
