Author Topic: JBL creature touch volume not working when not grounded  (Read 1079 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: May 25, 2020, 09:41:32 am »
I have one of these JBL creature
And the  touch buttons only work if it is connected to a device that has EARTH/GROUND.
The Creature's SMPS wall socket side has just the line and neutral, no EARTH.
If I connect it to my TV that has only line and neutral volume does not work. If I connect it to my keyboard that has an earth at the wall socket the volume works.
Also interestingly... if I touch the negative terminal of the audio input plug and touch the volume it works.
Could someone explain the reason why earth is required? Is there a work around it or it is a natural limitation of this product?
Is it silly to add a 3 pin socket to the primary side of the SMPS and connect the ground to the negative terminal of the secondary side. Similar as when you ground the negative rail?
« Last Edit: May 25, 2020, 10:33:43 pm by gkmaia »
Offline Kaluluka
Re: JBL creature touch volume not working when not grounded
« Reply #1 on: July 09, 2021, 06:29:20 am »
Hi!
I know , this is a bit old posting , but anyway:
Do you use original JBL power supply for it?
I ask because: Original Power supply provides AC 18 Volts , not DC!
Regards,
Offline Cyberdragon
« Reply #2 on: July 09, 2021, 07:46:58 am »
It's probably a capacitive touch sensor relying on a ground reference. If the machine is not grounded when you touch it, it will just remain floating and have no potential difference to trigger the sensor. (you also create a potential by connecting yourself to the DC common point). If it's just a 2 pin AC transformer, it'll be relying on something like inter-winding capacitance (or have some sort of Y cap across it, unsure, haven't had one of these to examine).
Other capacitive touch sensors such as those for screens get around this by referencing to themselves through creating a tiny AC field feeding back on itself that gets disturbed when contacted, and can electronically filter out anything not a finger or stylus that recreates that feild distortion, basically like a metal detector except with capacitance instead of inductance.
*BZZZZZZAAAAAP*
Voltamort strikes again!
