Author Topic: Fluke 95 Oscilloscope Sampling  (Read 4610 times)
Offline Tony RTopic starter
« on: September 25, 2011, 02:22:59 pm »
So i was browsing the pages of ebay and i found an add that got me a little confused and hope some of you guys can help clear it up for me
I found a Fluke 95 50 Mhz hand held scopemeter. in the add it stated "*** 50 Mhz Dual Channel *** 25 Megasamples/second ***"
Now when taking signals and systems i was always told that your sampling frequency must be at least twice the frequency of the signal you want to sample so fs>= 2*f.
So if this is sampling 25 million times a second, how can it be rated for 50 MHz waves?
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,  IEEE Student Member
Offline Zero999
  • 0999
Re: Fluke 95 Oscilloscope Sampling
« Reply #1 on: September 25, 2011, 02:32:16 pm »
It'd possible to have a higher analogue bandwidth than double the sample rate for repetitive waveforms.
Alex
  • Guest
« Reply #2 on: September 25, 2011, 02:35:34 pm »
Ahh, used to have that one!
Sure, look up equivalent time sampling. Here is a dcent app note:
http://www2.tek.com/cmswpt/tidetails.lotr?ct=TI&cs=Application+Note&ci=14295&lc=EN
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: September 26, 2011, 10:51:12 am »
2x is minimum, realistically its 10x.  So that scope is effectively 2.5 MHz worse case, in single shot applications.
Best Wishes,
 Saturation
