Author Topic: What is the name of this piece?  (Read 1933 times)
Offline AlxTopic starter
« on: May 14, 2019, 05:57:20 pm »
Hi
, I want a piece I want to order in China for me. But I do not know the technical name. I have put a piece of the picture. Those who know the technical name please tell me
Offline Ampera
    • Ampera's Forums
Re: What is the name of this piece?
« Reply #1 on: May 14, 2019, 05:59:32 pm »
It's called a piece of metal.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
The following users thanked this post: hans, blueskull, Ysjoelfir
Offline German_EE
« Reply #2 on: May 14, 2019, 06:03:48 pm »
It looks like the sort of thing that is fitted to the range switch of a multimeter, I would call it a spring contact but there may be a better name. If you want half a million made then the Chinese are the right people to see, if you want one then good luck!
Send them the CAD files and see what they say.
Edit, if you want one making then go speak to someone who repairs watches, it's surprising what you can achieve with skill and the right tools.
« Last Edit: May 14, 2019, 06:20:15 pm by German_EE »
Warren Buffett
Online thm_w
  • Non-expert
« Reply #3 on: May 14, 2019, 08:38:27 pm »
Send them the photo and explain, what its contacting with or plating requirements, I'm sure they will know what you are talking about?
https://www.alibaba.com/product-detail/China-Tin-plated-copper-electrical-contact_60331473364.html
https://www.alibaba.com/product-detail/Customized-Stamping-Brass-Battery-Leaf-Spring_60527862017.html
Offline G7PSK
  • It is hot until proved not.
« Reply #4 on: May 14, 2019, 09:10:11 pm »
A wiper contact or contact wiper, whichever way arround you like.
Offline ebastler
« Reply #5 on: May 14, 2019, 09:34:49 pm »
You are aware that, if you want this exact geometry and dimensions, it will be a custom-made part, right? You are extremely unlikely to find this off the shelf.
Offline windsmurf
« Reply #6 on: May 14, 2019, 11:44:05 pm »
Hi
I'd call it a spring contact.
https://www.harwin.com/videos/multidirectional-spring-contacts/
The following users thanked this post: Wendy_Preston
Offline Brumby
« Reply #7 on: May 15, 2019, 04:12:22 am »
As everyone has said - it's a spring contact ... but please read this post again:
There are literally tens of thousands (or more) variations on this sort of thing and each will have been designed for a particular mechanism.  I, too, would not expect you to find this as a separate part.
The only high probability means of obtaining such a contact would be to find out what switch, potentiometer or other mechanism it came from and buy another.  I say "high probability" rather than guaranteed because there's always the chance that the manufacturer may have changed the design.
« Last Edit: May 15, 2019, 04:15:45 am by Brumby »
Offline Richard Crowley
  • KJ7YLK
« Reply #8 on: May 15, 2019, 05:48:38 am »
If you need 100,000 of them, you can send them the sample (or the dimensions) and they will make some for you.  That is a full-custom part made for an OEM product and you will never find anyone to sell you "a piece".
Absent any context or details or motivation, we really can't know where to begin any possible suggestions.  If you want to tell us what you are trying to do, there may be some useful suggestions here.
If you are trying to repair something with this in it, you are likely approaching the process from the wrong premise.
Offline soldar
« Reply #9 on: May 15, 2019, 05:46:56 pm »
Hi , I want a piece I want to order in China for me.
Just send the photo to my uncle, Xi Jinping (you might have heard of him) and tell him I sent you. He'll take care of everything for you.
Just be a little patient if you don't get a reply right away because he's kind of busy these days with a tariff war he has going on with some other country or other.
« Reply #10 on: May 15, 2019, 06:16:21 pm »
Thanks all the friends for the answer :)
I need a lot of this piece
  • KJ7YLK
« Reply #11 on: May 15, 2019, 09:37:58 pm »
I would call it a "spring contact".  Typically made of phosphor-bronze, etc.
Beyond the obvious specifications (dimensions, thickness, tolerances, material, etc.)
There are dozens of variable factors depending on your application. Like:
How "springy" does it need to be? (metal alloy, thickness, etc.)
What is it going to be bearing against?  (copper on fiberglass PC board?, contact points molded into some custom plastic part?)
How many cycles do you expect for its life-span?
Does it need to be low-resistance?  (like gold contact surfaces)
I'm sure there are dozens of other factors that I didn't think of at the moment.
Offline Wendy_Preston
  • Content Marketing Specialist for Harwin
    • Harwin.com
« Reply #12 on: May 24, 2019, 10:06:26 am »
Hi
Appreciate the link, thanks, windsmurf. However this particular spring contact defiinitely looks designed to be part of a mechanism or connector of some sort. Our spring contacts relating to that link are useable as stand-alone items - surface mount to your PCB and bingo, one spring contact ready to make contact with another surface.
Definitely agree with the other contributors that this is incredibly unlikely to be off-the-shelf anywhere. It will almost certainly be made to specific requirements - which, as Richard Crowley lists, there are many performance factors that need to be considered. Just copying the shape is only half the story.
Depending on your volumes will depend on how you get it made, too. Lower volumes, you can get the profile chemically etched and individually formed and plated. Higher volumes, you could get the thing done in a stamping press, keep it with adjoining tabs so it tis reeled, and run it through a reel plating line. Typically this would be for volumes of hundreds of thousands minimum though. But the manufacturers that you approach can advise your best route and if the volumes fall within their remit. Target price will help them evaluate too. Good luck!
Content Marketing and website technical content for Harwin (ex Design Engineer) - contact me on webmaster@harwin.co.uk.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #13 on: May 26, 2019, 08:56:39 am »
As a potentially helpful suggestion for questions like this in the future, it would be a good idea to include something else in the photo along with the object in question to allow us to grasp the size.  Perhaps a commonly known coin, or, even better, a ruler or scale positioned next to the part.  It's difficult to assess the size of the part with nothing but a blank background for reference.
-Pat
Online coppercone2
« Reply #14 on: May 28, 2019, 01:26:24 am »
something you hire a electromechanical design engineer for
