I have a bookmark collection of references like these broken down by category. Makes it easy to locate "the best" when I need a reference.
The one laminated reference I do keep on hand has a drawing of the microcontroller circuit board I use for most of my projects with the port pins for every connector pin, LED and switch called out.
One handy thing on the back side, a table showing the limits for each variable type.
