Author Topic: Etching at Home  (Read 25069 times)
Offline smashedProton
Re: Etching at Home
« Reply #50 on: January 30, 2013, 11:52:21 pm »
Gk, that's beautiful!  Excellent work.  A+ :D
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline GK
Re: Etching at Home
« Reply #51 on: January 31, 2013, 03:09:26 am »
Thanks!
If you are trying to measure current and have high voltages, watch out for leakage.
According to the datasheet for the Electrolube CPL, the insulation resistance is 1 x 1012 ohms/cm, though I guess the real figure would depend on how thickly you layer it on.
http://www.farnell.com/datasheets/392349.pdf
There are more expensive coatings, such as the Electrolube HPA:
http://www.farnell.com/datasheets/316960.pdf
..... which has a quoted insulation resistance of 1 X 1014 ohms/cm, but the cheaper stuff is quite fine for most applications.
It's anyones guess as to what's in the can from Jaycar though.
« Last Edit: January 31, 2013, 03:16:30 am by GK »
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline nukie
Re: Re: Etching at Home
« Reply #52 on: January 31, 2013, 12:16:17 pm »
Something else you can use to keep the copper from tarnishing is a permanent marker, but I don't use the black sharpee brand ones. I use some colored markers that are sold cheap in packs of 6 colors. The colors are sort of useful because you can use the different colors to color code parts of the board by their function. The ink burns off when the trace is heated so no problem to remove.
Anything wrong with solder-through conformable coating?
That's professional looking board. Does the coating gives off dangerous fumes?
tapatalk
Offline GK
Re: Etching at Home
« Reply #53 on: January 31, 2013, 01:04:47 pm »
From the datasheet:
"Can be soldered through without fear of highly toxic gases being produced (contains no isocyanates)."
Offline nukie
« Reply #54 on: January 31, 2013, 02:51:47 pm »
From the datasheet:
Im going to keep that in my notes very useful thanks. Does the solder flow well with the coating melt mix?
tapatalk
Offline GK
Re: Etching at Home
« Reply #55 on: February 01, 2013, 09:43:55 am »
Yeah, it's fine. So long as you don't layer on five coats you'd hardly notice it was there.
