Author Topic: Which Metcal tip for batter case solder lugs ?  (Read 820 times)
Offline onesixrightTopic starter
« on: January 11, 2019, 04:59:43 pm »
Hi All,
I using a STTC-146 Metcal tip. Now the other day I was soldering a battery lug, and within 1-2 seconds the lug got wrapped inside the battery case.
One like this: http://www.batteryholders.com/part.php?pn=BCAAL&original=AA&override=AA
Guessing to much power. I hardly touched it |O
So, either my soldering skills suck (probably), but maybe its the wrong tip? Any tips?
Thanks!
Online Gyro
Re: Which Metcal tip for batter case solder lugs ?
« Reply #1 on: January 11, 2019, 08:22:56 pm »
The plastic in those cheap battery holders melts if just look at them in the wrong way. The secret is speed - make a decent mechanical connection between the wire and the lug, tin the soldering iron bit well and go in really fast with some fresh solder. Aim to make the joint in less than a second with minimum mechanical pressure.
If possible, get holders with wires pre-crimped.
P.S. As far as I can see, there is no 'correct' bit - the plastic just melts at a lower temperature than the solder.
« Last Edit: January 11, 2019, 08:28:27 pm by Gyro »
Best Regards, Chris
« Reply #2 on: January 11, 2019, 08:53:48 pm »
Hi Gyro,
I thought there was to much power in the tip. I will give it a try.
Thanks!
Sent from my X using Tapatalk
Offline KJDS
    • my website holding page
« Reply #3 on: January 11, 2019, 10:02:59 pm »
My preferred metcal tip, and as has already been stated, speed is the key. Put some flux on the joint too.
https://eu.mouser.com/ProductDetail/Metcal/STTC-1173P?qs=kSX8PZDGYsscR4QSugzdQw==
