Ok - a little bit more information.
Depending on what part of the world you are in, there are at least 3 different IP addresses for
www.supplyframe.com.
So if one of the servers is overloaded, only the people connecting to that server will have a problem. For everyone else, it will be fine.
Now it gets a bit more complicated. If the
www.supplyframe.com link works, then you are redirected again to ads.supplyframe.com which has at least two different addresses depending on where you are in the world. So if you are connected to the overloaded server again, you will loose your Find Chips bar.
Last, because the ads.supplyframe.com site begins with "ads", if you have loaded any kind of add popup blocker, it will probably kill the Find Chips bar as well.
Richard.
