Explanation message :
1) The true silicone it will remain soft no matter what, but the cable insulation are an mixture.
2) The " Standard " version TL-75 , it will had one more soft feeling, in hot climates than the cold ones.
3) The measurement of millivolts , demands the most low in resistance cable leads.
Every extra Ohm on the cable leads, it will lower the voltage value by allot.
That's my understanding ... at list .
I'm afraid not,my friend,think of it this way :-
Across say:- 10mV we have a voltage divider consisting of the DMM input impedance,around
11MegOhm,& the total resistance of the two test leads at about 0.3 Ohm.
My Calculator hasn't got enough decimal points to tell the difference between the DMM reading in this case,& the reading with perfect leads of zero resistance.
Where lead resistance comes in is for low
current readings.
VK6ZGO
