It is clear your sources are wrong (as random Youtube videos often are) because they do not take into account that farming methods can be improved / changed to give higher yields from the same area of land. The ability to do so will go hand in hand with improving the economy of such countries which needs to start by ending the local wars and improving education.
edit: typo
They aren't "random" youtube videos. They are videos I choose specifically because they provide citations and I think they are well written and well researched. Kurzgesagt in particular provides extensive source documents and consults SMEs for their videos (sources for climate responsibility video
https://sites.google.com/view/sourcesclimateresponsibility/). I have also provided other articles and written sources if videos are so offensive to you. You can also look at the sources used in any of the videos as listed in their descriptions.
Edit: Relevant, new (May 2021) report. Explicitly includes yield gains. Reducing meat and milk consumption is major part of the recommendations in addition to other strategies.
https://www.wri.org/research/pathway-carbon-neutral-agriculture-denmark Webinar form:
https://www.wri.org/events/2021/5/pathway-carbon-neutral-agricultureWhat evidence do you have to say that "they do not take into account that farming methods can be improved / changed to give higher yields"? Are you assuming the research and papers which the videos are based on fail to take that into account? Do you have any evidence the improvement you claim can be achieved and to a sufficient level?
I don't contest land use can be solved by the current rate of progression. I support that statement
and have in the past. Again, I'm not against the idea that technology can and should be used improve agriculture. If you read
my recent response to bdunham7, the issue is primarily greenhouse emissions, not land use. The videos and sources I've posted similarly cite greenhouse emissions as the issue and not land use so I wonder if you actually looked at them. My assertion is that this isn't "someone else's problem" or "whatever happens elsewhere doesn't concern me" due to global impacts from greenhouse gas emissions, global responsibility should be taken.
The natural progression would then be "they do not take into account that farming methods can be improved/changed to give higher yields from the same GHG emissions". So I did some research there and found some data which provided some new information and changed my mind a bit.
https://www.climatewatchdata.org/sectors/agriculture Total World GHG emissions from agriculture are
still rising and do not appear to be plateauing or reducing so
there definitely needs to be more done to reduce Agricultural emissions. If we look at per capita GHG emissions however, there is a strong reduction in the past 60 years. So
despite improving agricultural allowing more people to be fed using less GHG emissions, the total emissions are still rising. A point to "overpopulation"?
Interestingly
GHG emissions per GDP has plateaued so the ability to further reduce GHG emissions through economic development seems limited and
already developed nations have limited capacity to further reduce emissions at the current rate. This graph could be more useful as a log vertical scale.
I'll just post my observations instead of filling this post with endless attachments from here. You can look at the graphs yourself by following the source linked above.
Emissions per capita for OECD countries also seems to have levelled out in the past decade at 880 to 960 mt per capita further confirming
an impasse has been reached for reducing GHG emissions in developed countries.
Emissions per capita for "least developed countries" are at 960mt per capita in 2018.
Least developed countries are already parity with developed countriesEmissions per capita for Nigeria (
expected to be third largest in the world by 2050) Approximately net even change over the past 30 years. 350 mt per captia in 1989 and 360 mt per capital in 2018.
Nigeria is likely to see significant increases in Agricultural emissions?Emissions per capita for US Similar OECD,
lack of change in emissions per capita in last decade. 1.1 t per capita in 2009 and 2018.
Emissions per capita for India Some downward trend but limited. 520 mt per capita in 2007 and 480 mt per capita in 2018.
Emissions per capita for China Was increasing up to 1996 550 mt per capita peak then decreasing to 480 mt per capita by 2003 followed by stability then recent drop to 460 mt per capita in 2018.
Stable then recent decreaseEmissions per capita for Australia is a whooping
6 t per capita in 2018 but decreasing. Perhaps due to large agricultural export in Australia?
It seems to me that GHG emissions from Agricultural activities do have room to improve over the world with a downwards trend in per capita emissions globally but
the current rate of improvement isn't sufficient to offset population growth leading to a continued increase in global GHG emissions due to agriculture. The downwards trend in per capita emissions appears to be due to a significant fraction of developing nations reducing per capita emissions but even the least developed have little rooms left to improve. If the largest developing countries (Nigeria, India, China) were to reach towards GHG emissions per Capita of first world countries such as the US by copying the consumption/production habits even with their "modernised" agriculture then the rise in GHG emissions would be much worse but fortunately this doesn't seem to be happening.
Developed countries aren't reducing GHG emissions per capita in the last decade. Unlike land use, GHG emissions for agriculture are not seeing an improvements in emissions with the benefit of being developed. And let's not forget, the need is to become carbon neutral, not just stopping GHG emissions rising.
With regard to who is responsible and should be taking action, see
the Kurzgesagt video posted previously.
I guess at best you could maybe contest developing countries will start to reduce their GHG emissions per capita even faster once more developed? but that seems unrealistic given they are already on par with developed countries and the most populous ones I looked at are already ~50% GHG emissions per capita of first world countries.
This is just looking at numbers and graphs so could definitely be missing the trees for the forest. It's also definitely not a full numerical analysis either. Data is a little bit dated too. I expect 2020 and 2021 will have a pretty massive dip due to COVID.
If anyone else can provide an alternative source for analysis that would be useful.
