Loading [MathJax]/extensions/Safe.js
Author Topic: Feedback on ground - philosophical question  (Read 690 times)
Offline bernrothTopic starter
« on: January 25, 2022, 07:52:09 am »
Dear all,
first of all: This makes possibly no sense and is for fun only
Yesterday when I was driving home in my car, I listened to a song which went like "Get down, put your feet back on the ground..."
I thought... that's interesting: What happens when I actually put my feedback on ground?  ^-^
In normal circumstances that's a bad idea to short an opamps output to ground.
Are there any practical applications actually doing so by purpose?
Attached a Q&D idea of common grounds of supply and "output". This might be quite unstable.
What I've seen already is an opamp creating a virtual ground for another part of the circuit.
Take care!
Cheers,
Bernhard
« Last Edit: January 25, 2022, 07:54:00 am by bernroth »
Offline newbrain
Re: Feedback on ground - philosophical question
« Reply #1 on: January 25, 2022, 08:22:38 am »
Not the feedback, but shorting the output to ground is not so out there.
Many small power amplifier designs exploit the differential current draw on the supplies, e.g. the attached one (from Elektor).
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: January 25, 2022, 10:23:46 am »
Well, that makes a comparator.  Note that the input signal is ground-referenced (assumed), so the amp can only compare its value to ground, and draw either short-circuit current from the respective pin, or saturate down to V_OH/V_OL as the case may be.  Note that only one or the other supply will be active at a time, so the bypass cap isn't helpful here.  Probably.
This is where we need to know the true nature of an opamp.
Most have a class AB to B output stage, meaning that quiescent current flows + to -, and that current doesn't change much, while the output current adds on top of it, in the respective direction (+V to OUT / OUT to -V).
Some have a fair amount of class A; whereas LM358 is class B (in fact having noticeable crossover distortion even), NE5534 is notoriously deep class A (to the extent that, operated at rated supply voltage, the chips are prone to overheating!).  In class A, we expect the balance of quiescent current to shift, at least until one side or the other enters cutoff, and then the above will be true.
So it is, with the "probably" I left above.  In class A, the supply current remains constant and the balance shifts, thus the bypass capacitor sees no current flow (not to say it's irrelevant, more that it's able to do its job, so to speak) and the outputs shift in kind.  In class AB, only one side moves inward depending on input polarity, and the capacitor will actually act to pull the opposite side opposite its active direction!  This may be an unintended effect of your scheme -- but it may be quite intentionally used, as a kind of absolute-value function, say?  (Once stabilized with feedback from the circuit output, of course!)
As it happens, a similar sort of topology is even used to model the supply currents in many op-amp simulation (SPICE) models themselves.  I'm... not sure that there's much documentation about this out there; and, hrm, I've worked on such models before, but I don't seem to have any screenshots handy, unfortunately.  So, I'll leave this as flavor, I guess.
Seven Transistor Labs, LLC
Offline Siwastaja
« Reply #3 on: January 25, 2022, 11:12:37 am »
Nice to hear someone else came up with this joke.
Whenever I have a circuit with
 * a feedback, and
 * ground,
which arguably quite often happens, I can't avoid starting to sing, very loudly,
Put me up, put me down, put my feedback on the ground!!
Or something like that. I suck at remembering lyrics correctly, but that doesn't prevent me from forcing others enjoy my performances.
Similar thing happens whenever I need a "countdown" in firmware. It's a final countdown, tididiidiii, tididididdii! If it goes on for more than a day, wife may start protesting.
« Last Edit: January 25, 2022, 11:14:31 am by Siwastaja »
