Author Topic: Electronic workbench fire  (Read 8195 times)
Offline ez24Topic starter
  • L.D.A.
« on: July 24, 2018, 07:38:45 pm »
Hi
Found an interesting video on this forum at https://www.eevblog.com/forum/reviews/zd-939l-hot-air-station-2-minute-teardown!/msg1070546/#msg1070546
The fire starts at about 50 sec in the upper right, it starts to glow first.  It is a soldering station.
Does anyone have any electronic workbench fire videos they wish to share?
Whats with the toilet seat - electronic one?
The following users thanked this post: TheNewLab
Offline glarsson
Re: Electronic workbench fire
« Reply #1 on: July 24, 2018, 07:59:03 pm »
A small one with a magnifying lens in the seat? It's something else; something rather common on the workbench.
Offline BillB
« Reply #2 on: July 24, 2018, 07:59:27 pm »
That's scary.  And that's also why I have a camera pointed at my workbench as well.
Offline glarsson
« Reply #3 on: July 24, 2018, 08:04:21 pm »
About that "toilet seat": You should close the lid when leaving the bench if your shop has windows. Otherwise you might find a second method to set your workbench on fire.
The following users thanked this post: Tom45, tooki
« Reply #4 on: July 24, 2018, 08:29:33 pm »
This is one reason I dumped the T12 iron I had and bought a Metcal. 90% less likely to burn your house down.
Offline hans
« Reply #5 on: July 24, 2018, 08:32:00 pm »
The reason why I've got all my gear hooked up to a single circuit breaker such that I can turn off my whole bench when I'm out.
Ofcourse the point is to then actually use it.. :-//
« Reply #6 on: July 24, 2018, 08:45:18 pm »
Actually when I did my amateur radio license stuff recently that was in the exam. Single isolation switch on the bench. Basically so whoever walks past, smells bacon and finds you smouldering away stuck to an anode cap on a 1KW valve PA on a bench can turn it off so they don't end up long pig as well.
Offline aargee
« Reply #7 on: July 24, 2018, 09:50:28 pm »
It looks like the fan failed in the handle of the hot air gun, the element just did it’s thing.
It should have been off when on its holder, I try and keep my Chinese one manually off when I’m not at the bench.
Not easy, not hard, just need to be incentivised.
The following users thanked this post: TheNewLab, tooki
Offline metrologist
« Reply #8 on: July 24, 2018, 09:54:28 pm »
bidet repair gone wrong
The following users thanked this post: blueskull, bd139
Offline NivagSwerdna
« Reply #9 on: July 24, 2018, 10:17:56 pm »
I never leave my combined solder/hot air station plugged in when unattended.... I came back to it once and found it very hot... even when OFF
Offline Monkeh
« Reply #10 on: July 24, 2018, 10:32:47 pm »
Use the light switch.
Offline richnormand
« Reply #11 on: July 24, 2018, 11:20:28 pm »
Interesting video.
I have a Sunko (ebay look alike) hot air station with the same hot air wand as in the video.
When I turn it off after use the fan will operate for a while to cool the tip.
But I noticed that when I turn off the main power to the whole workbench, when I leave for an extended time, on return, when I power up the bench back on the cooling off fan on the Sunko does turn on for a while and then turn off, like in normal use.
That is while the main Sunko front switch is off. That means the unit is still live even when the front panel switch is off, all the time.
I guess a simple line transient could get an SCR (for the heater) full on with no fan, depending on the logic used to control the unit...
Thanks for the video indeed. It should get more visibility.
My unit is getting pulled tonight and will get a real on/off switch hooked to front panel right at the mains right now.... :scared:
« Last Edit: July 26, 2018, 01:57:57 am by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
The following users thanked this post: ez24
Offline Brumby
« Reply #12 on: July 25, 2018, 12:23:36 am »
I have one of those cheap dual hot air/soldering workstations and it does have a mechanical "off" switch ... on the back panel.  This makes it inaccessible unless I pull it out of the little shelving unit I made, so it just stays turned on.  However everything in that unit runs off a master switch which only gets turned on when I want to do soldering work, heatshrink or dry something off - or if I want power from a bench supply.
This rear mounted switch actually works in my favour, since that unit will always have something displaying on one or more of its red LED displays and being in a prime position in my peripheral vision, I have a "power on" indication.
I also have a master switch for my computer (and associated peripherals) and another for the photographic lighting.  Yes, it's a very multi-purpose work desk.
Offline SparkyFX
« Reply #13 on: July 25, 2018, 02:03:29 am »
Got a similar rework station, they do have a delayed shutdown to cool the heater down, therefore prolonging its lifetime, automatically switch it off while in its bracket... in this case maybe the source kept supplying power to the heating element anyway (no visible air flow in the video).
I try to not keep hot tools next to inflammable material and switch the whole unit off when leaving the bench for some time, because you never know and there is no perfect product (even repair tools break, actually they are more likely to break because of additional abuse).
Support your local planet.
Offline amyk
« Reply #14 on: July 25, 2018, 02:56:42 am »
I guess a simple line transient could get an SCR (for the heather) full on with no fan, depending on the logic used to control the unit...
Yes, these mains-element hot air stations connect the heater directly to the mains using only a triac. If it fails shorted, the heater turns on while the control electronics which power the (low voltage) fan don't... and a meltdown soon happens.
I suppose a simple workaround might be to connect the fan to the element through a simple capacitive dropper or similar, so that whenever the element gets voltage, so does the fan.
Thermal fuses might be an option but they don't seem to go much beyond 240C which is a normal operating temperature for a hot air station.
Offline Tom45
« Reply #15 on: July 25, 2018, 03:27:35 am »
Back when I was in college in a dorm room I was sound asleep on my bed and my roommate was studying at his desk. Then his desk lamp erupted with an impressive shower of sparks that would put a roman candle to shame. I jumped up still half asleep and ran around the room in a panic. By the time I became fully awake, the lamp had burned itself out.
I now have separate outlet strips. One is for devices that need to be on all the time such as GPSDO and counter/timers and bench meters that go into standby when you use their power switch. One is dedicated to soldering station and hot air station. I turn that off whenever I leave the room.  Other circuits are for test equipment such as scopes that can be turned off when not in use, and a circuit for powering devices under test.
Offline Dubbie
« Reply #16 on: July 25, 2018, 05:01:50 am »
Hrm I have one of these things....
Makes me realise that I should turn it off when I am not using it. Which I don't at the moment...
Good cautionary video!
Offline stj
« Reply #17 on: July 25, 2018, 12:32:39 pm »
nothing is "safe" to turn your back on.
i have seen the older type of cheap hot air unit with the pump in the base  latch the heater on and glow - destroying the handle,
i have had an old analog weller desoldering unit glow red from a failed triac,
i have had an old steel-cased fan heater shower the floor with sparks when the gromet failed and the case rubbed into the power cord,
and most annoying, i have had a regular lamp bulb explode when i switched it on.
worst part about that was it was on the staircase, so i had to climb a ladder to use long-nose pliers to try to extract the lamp base from the holder afterwards!!
Offline Red Squirrel
« Reply #18 on: July 25, 2018, 01:27:09 pm »
The thermal design of it just didn't account for Taco Bell.  >:D
Actually this reminds me, I was testing water sensors once, just a cheap ebay buy.  I set it on the bench and put a drop of water on it.  Turned around to look at my computer to see if the alarm condition came in.  Turn back around and immediately I have smoke in my face.  The sensor caught on fire.  I guess these sensors are for if your insurance covers fire, but not flood so you stick these around your house. lol.
Still have not done anything with them.  I imagine adding a current limiting resistor in right place would stop the fire from happening.
« Last Edit: July 25, 2018, 01:30:24 pm by Red Squirrel »
Offline Eka
« Reply #19 on: July 25, 2018, 05:19:13 pm »
That's why I have power strips for powering groups of stuff on my bench. One is solely for the lighting. Another is for the computer. The next is for test instruments like the oscilloscope. Another is for the soldering irons, etc. Lastly there is one for powering projects. I can turn everything off at the line conditioner, and the computer and lights off at the UPS. This allows me to test circuits, and have the heat producers like the soldering iron off and unpowered when not needed. Likewise when I'm soldering up a circuit I can have the test instruments and project power supplies off. When I walk away from the bench I just have to switch off the power strips and everything is off.
Oh, I don't trust my soldering equipment. They sit in a steel pan when not in use. They could burn up in it, and not burn down the place.
I also have a medium sized CO2 fire extinguisher close at hand in case it's needed.
Offline james_s
« Reply #20 on: July 25, 2018, 06:16:10 pm »
I never leave soldering/desoldering gear turned on and unattended for any longer than it takes me to go take a leak. My bench is all plugged into a power strip which also powers the light above it. I've gotten in the habit of shutting it off whenever I'm done working for the time.
Offline richnormand
« Reply #21 on: July 25, 2018, 09:32:18 pm »
To follow up on my previous post.
"My unit is getting pulled tonight and will get a real on/off switch hooked to front panel right at the mains right now.... :scared:"
First picture shows an "OFF" means "OFF" switch that is now installed on the front panel with a monitor light.
From amyk:
"these mains-element hot air stations connect the heater directly to the mains using only a triac. If it fails shorted, the heater turns on while the control electronics which power the (low voltage) fan don't... and a meltdown soon happens.
The second picture is the triac that controls the heater and a quick look at the circuit looks like indeed it could possibly just come on, with no fan, if shorted by a line transient."
I looked at my Pace solder iron, the Pace desolder station and the Weller WX2 and when they are turned OFF at the main switch they are OFF, only this Sunko was still alive with full AC when officially in the OFF position.
« Last Edit: July 25, 2018, 09:38:18 pm by richnormand »
Offline Dubbie
« Reply #22 on: July 25, 2018, 10:38:09 pm »
Good idea. I am going to add a similar switch to the front panel of mine.
Offline wraper
  • Country: lv
« Reply #23 on: July 25, 2018, 10:45:20 pm »
Nope, as written in description, station does not have power switch. It just started heating by itself. I guess triac failed short.
Offline wraper
  • Country: lv
« Reply #24 on: July 25, 2018, 10:57:32 pm »
Thermal fuse doesn't need high temperature rating. All you need is placing low temperature thermal fuse just  before the heater. Thus if heater is powered in the absence of airflow, it will trip. I just took apart handle of my Quick 861DS and yep, it has thermal fuse before the heater.
