Hi guys,
I am building a power supply with a 3055 transistor. With 0-24V output and also with current limiting function.
I prototyped it on a breadbroad and it works fine, the voltage goes all the way down to 0.050V. Good enough I guess.
I want to have a panel showing the output terminal voltage and the current flowing. Also POWER by just multiplying voltage and current in arduino code.
I have a ADS1115 16bit ADC laying around and I want to use it in this project for sensing voltage and current which would be perfect for this project.
I am not sure whether to put the shunt on High side or Low side.
Thank you
With Regards
Sarvesaa Jagan
