Author Topic: Use a washer to make an angle grinder disc fit?  (Read 5589 times)
Offline XOIIOTopic starter
« on: September 11, 2014, 07:28:54 pm »
Hey all, got a cutting disc for my angle grinder, however it is too think by a little bit, I figured they would be universal but I guess not.
Anyways, most of the ones I saw were that thin and the place I bought it is fairly far away, so I was thinking maybe a washer would work to hold it down? I suppose there is more risk of it slipping, but I figure for the somewhat light work I'd be doing it might work  well enough :-//
Re: Use a washer to make an angle grinder disc fit?
« Reply #1 on: September 11, 2014, 07:31:23 pm »
Flip the locking nut around and it will grip properly. The nut has a lip on one side for the thick disks and the back side has a recess for the thin ones.
Offline Biff383
  • Oh Crap!!!
« Reply #2 on: September 11, 2014, 07:32:06 pm »
  Should be OK did you try flipping the retaining nut over?
Offline Monkeh
« Reply #3 on: September 11, 2014, 07:32:39 pm »
The nut or filler washer should be reversible to deal with different size discs.
« Reply #4 on: September 11, 2014, 07:46:04 pm »
Ah, didn't know it was reversible, works great lol, thanks guys.
Offline calexanian
    • Alex-Tronix
« Reply #5 on: September 12, 2014, 04:39:58 am »
The retaining nut is two sided. One for thin cutoff discs, and the other has a thicker collar for grinding disks.. Danger if you get it backwards...
Charles Alexanian
Alex-Tronix Control Systems
