Author Topic: EEVblog-Like Forum for Mechanical Engineering?  (Read 6026 times)
Offline Technobabble_Topic starter
  • Novice. Self-Certified Fabricobbler
« on: January 21, 2018, 06:59:06 pm »
The title says it all. I know about Hackaday and Thingiverse, but they don't exactly have the same feel. What other fourms do you recommend for mechanical engineering stuff?
Offline Dubbie
Re: EEVblog-Like Forum for Mechanical Engineering?
« Reply #1 on: January 21, 2018, 07:17:33 pm »
For machinebuilding, CNCZone is ok-ish.
What particular area of mechanical engineering are you interested in?
Offline rhb
« Reply #2 on: January 21, 2018, 07:50:50 pm »
I suspect you'll find plenty of people around here.  I've got a lathe, mill, welder, etc.  Actually several of each, but that's another story.  I'm quite happy to mix it up with mechanical engineering. How exotic do you want to get?  If you go as far as the mechanical properties of porous media I know quite a lot.  Less exotic, not so much.  Solid grasp of the basics, but slow from lack of education and practice.  On the plus side, I have a 5000+ volume technical library.
The older crowd here seems to have done everything one can imagine at some point.  Reminds me of Usenet in the late 80's and early 90's and the folks I worked with at oil company R&D labs.
Read the "has anyone built a mass spectrometer" thread.
Have Fun!
Reg
The following users thanked this post: Galenbo
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: January 21, 2018, 08:55:39 pm »
maybe Dave should create a mechanical subsection engineers will be engineers and not compartmentalize their skills and interests, that is the point of engineering.
The following users thanked this post: jeremy, Galenbo, cdev, blueskull, ez24, ChunkyPastaSauce, PartialDischarge, s8548a
Offline AllTheGearNoIdea
    • AllTheGearNoIdea
« Reply #4 on: January 24, 2018, 08:56:28 pm »
I think I would quite like to see some form of mechanical engineering I’m especially interested in rapid prototyping 3D Printing and CNC milling for circuit boards etc. Been questions I have wanted to post but wanted to avoid taking the other forum section off topic.  I know Dave Jones had an interest in CNC for a while didn’t he have a milling machine in his store.  Oh we’ll cannot please everyone all the time and there is just not enough hour in the day.
My best regards to everyone on the forum
We all know failed electronics engineers become software engineers
I’m a failed electronics engineers so mechanical engineering looks like the next step for me
Chris
« Last Edit: January 24, 2018, 08:58:34 pm by AllTheGearNoIdea »
AllTheGearNoIdea Where Its All About The Gear
Offline Brumby
« Reply #5 on: January 25, 2018, 02:36:25 pm »
I can see how Dave might resist this idea.  Keeping electronics as the focus has been a clear objective he has maintained all along - at least through all the content and discussion I have been exposed to.  I can understand that.
At the same time, electronics has made extensive inroads into many mechanical processes with lathes, milling machines and a host of other CNC equipment - and now we have laser cutters, 3D printers and a whole new world of manufacturing where electronics is an integral part.
We have had a number of threads where mechanical engineering subjects have been discussed - and these have been allowed to run, so there is no taboo as such, but is that an argument for a separate subsection?  I don't know.
Offline Simon
  • Global Moderator
« Reply #6 on: January 25, 2018, 06:47:47 pm »
Strangely mechanical and CNC forums have electronics sections....
The following users thanked this post: ez24
Offline Brumby
« Reply #7 on: January 26, 2018, 04:04:18 am »
Not the best logical argument.  It fails the converse test.
In the current state of technology - CNC discussions especially - rely on electronics.  Without discussions on that, the subject is extremely limited.
Electronics does not rely on CNC or mechanical engineering to the same extent - by a long chalk (if at all).  IF you were to completely eliminate any and all references to mechanical engineering and CNC from the EEVblog, the impact would be very limited and discussions on a wide range of topics would be completely unaffected.
Please note that I do not hold a position against the idea - but I wonder if it is necessary to create a separate section.
Offline Dubbie
« Reply #8 on: January 26, 2018, 04:56:23 am »
I would like one.
I like where electronics and mechanical engineering intersect. Robin Renzettis channel is a perfect example.
Offline ChunkyPastaSauce
« Reply #9 on: January 26, 2018, 05:07:56 am »
I would like one.
Mechatronics
Offline jeremy
« Reply #10 on: January 26, 2018, 05:11:28 am »
+1 for a CNC/mechanical section
Offline mtdoc
« Reply #11 on: January 26, 2018, 06:43:38 am »
While not strictly speaking mechanical engineering,  I'm finding The Hobby Machinist Forum to be quite EEVBlog like - with a mix of hobbyists and professional machinists. Even some MEs.
Offline Simon
  • Global Moderator
« Reply #12 on: January 26, 2018, 06:45:22 am »
Yes and no. You can barely work in electronics today without being able to work with enclosures and putting connectors through enclosures, this is near impossible without mechanical CAD. Every job i have done for someone has involved "mechanics" and my ability to deliver 3D models has been key. Customers also expect it now and this is backed up by the ability of even the low end packages to produce 3D models, from there you are into fitting things into enclosures and milling holes. I invested as much in a small mill than I did in my power supply or thermal imaging camera.
Offline Dubbie
« Reply #13 on: January 26, 2018, 06:54:49 am »
the hobby machinist has a weird evangelical christian vibe going on.
Offline mtdoc
« Reply #14 on: January 26, 2018, 06:58:18 am »
Ooh - really? Yuck. I'm a fairly new lurker there and haven't noticed that - at least not in the posters. Examples?
The forum originator does have some site history, etc stuff that is outside the regular forum postings but I haven't looked at that much and didn't pick up on the ec stuff.
« Last Edit: January 26, 2018, 07:01:59 am by mtdoc »
Offline mtdoc
« Reply #15 on: January 26, 2018, 07:08:13 am »
https://www.hobby-machinist.com/pages/siterules/
Wow. Just wow. I wonder if signing up for that site signs away my soul to him. Dave could learn a few things from this lunatic!  >:D
Those just seem like pretty common forum rules spelled out clearly for sure (in bold caps!) but nothing remarkable. Even though Dave doesn't spell them out, I'm pretty sure many of those rules are in force here when needed to justify banning people which does happen here (justly!) from time to time.
While I appreciate Dave and Simon's mostly hands off moderation here - IME, that is not really the norm for most quality internet forums.
Not to mention that his site is absolutely plastered with garbage ads. What an abomination.
Hmm. I see zero adds. None. But I do have Ad Blocker installed in my browser - as always.
Still not seeing any EC stuff..
Regardless - the actual content of the forum posts on machining, tools etc I think is very good.
Any reccomendations on other Machinist forums that are newbie friendly?
« Last Edit: January 26, 2018, 07:12:50 am by mtdoc »
Offline Brumby
« Reply #16 on: January 26, 2018, 07:25:10 am »
That's why I don't have a problem with discussion on the subject - but the truth be told, that's more of an adjunct than a core element of the subject of electronics.
Offline rx8pilot
« Reply #17 on: January 26, 2018, 07:29:31 am »
My CNC machine is literally 4 feet away from my pick and place machine.
In my world, EE and ME are truly a blended effort. My electronics are dependent on mechanics and my mechanics are dependent on electronics.
I would certainly welcome a discussion here for ME and CNC.
Short and misplld from my mobile......
Offline Brumby
« Reply #18 on: January 26, 2018, 07:33:40 am »
Yes .... Your setup is one that has been buzzing around in the back of my mind during all this...
Offline Simon
  • Global Moderator
« Reply #19 on: January 26, 2018, 07:44:59 am »
It's hard to know how much to spell out and how much not to. I think after past experiences Dave does state that you loose your copyright on anything you post but that is simply a legal angle to avoid problems. I'm sure if you ask nicely for a good reason you stuff will get removed if you can't be bothered to do it yourself.
Rules were not particularly lengthily on here until people took the micky and thought that a lack of clear rules was an invitation to cause trouble some were made up to keep them quite but I think as stated somewhere in the rules we will make a judgement at the time based on the situation and that's that, like it or lump it. It's worked so far.
Offline ivaylo
« Reply #20 on: January 26, 2018, 07:54:15 am »
+1 for mechanical section. Even Dave spends like 20% of say a design review on mechanicals and how are things put and kept together. Not always trivial...
Offline Circlotron
« Reply #21 on: January 26, 2018, 09:10:37 am »
I would like one.
Car engine and body electronics.
Offline Zero999
  • 0999
« Reply #22 on: January 26, 2018, 09:13:04 am »
I think it's a good idea.
Offline Simon
  • Global Moderator
« Reply #23 on: January 26, 2018, 02:17:56 pm »
My PCB layout library parts first start as a 3D model.....
Offline tszaboo
« Reply #24 on: January 26, 2018, 02:49:49 pm »
There's nothing more frustrating after spending $2000 on a prototype 8L PCB with impedance control and HDI, and another $2000 on a custom made CNC enclosure, only to find a stupid connector won't fit.
You print your design on a 1:1 scale. Find a cardboard that is about 1.6mm thick, farnell boxes are sometimes like that. Glue the paper on the cardboard. Cut it out. Make a x mark on TH components with . Place components on the cardboard. Try connectors, if you can reach it, have space for fingers,  it doesn't feel wrong, sticks out enough, etc.
99% of the time it works. I've saved a lot of prototypes with this technique.
+1 for the mechanical section. It is as important to electronics as software and firmware.
« Last Edit: January 26, 2018, 02:51:29 pm by NANDBlog »
The following users thanked this post: blueskull, ez24
