Author Topic: Microscope working area  (Read 3610 times)
Offline DavidDLCTopic starter
« on: June 22, 2012, 09:43:20 pm »
Can you change the vertical working area on a microscope by changing the eyepieces ?
Dave on a recent video mentions that you can do that by putting a wideview objective lens, I would like to try the eyepiece approach.
Please comment.
David.
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Microscope working area
« Reply #1 on: June 23, 2012, 01:45:59 am »
eyepiece will not change the working distance.
Offline Circuitous
    • Corgi-Tronics
« Reply #2 on: June 23, 2012, 02:20:32 am »
You can double the working distance by using a 0.5x Barlow lens, which goes in front of the objective lens.
http://en.wikipedia.org/wiki/Barlow_lens
« Reply #3 on: June 25, 2012, 06:25:22 pm »
Thanks guys.
I'm trying to get a 0.7x or 0.75x barrow lens.
David.
Offline Neganur
« Reply #4 on: June 26, 2012, 04:26:58 pm »
I'm using a 0.7X Barlow lens and it's just barely enough distance to work with ( 5" or 13 cm ). Consider a 0.5x lens or find a store that lets you test the difference.
« Reply #5 on: June 26, 2012, 05:41:11 pm »
Moi
Can you tell the difference on the distance for the working area with and without the barlow lens ?
I was looking for a store that will let me test the lenses, but the one I visited few years ago is out of business, now everything is pretty much on the internet.
David.
Offline StubbornGreek
« Reply #6 on: June 26, 2012, 08:01:14 pm »
Moi
David.
Yes, .5 will give you about 8 inches of work space (a good amount as it keeps your head at a distance where you won't get tired too easily and allows your hands to work at a natural position also).
"The reward of a thing well done is to have it done"
-Ralph Waldo Emerson
Offline EEVblog
« Reply #7 on: June 27, 2012, 12:53:39 am »
No, that will only change your total magnification.
To change your working distance you have to change your primary lens (or modify it with a barlow lens).
0.5x barlow lens are available on ebay for almost every scope on the market.
Dave.
