Author Topic: help with this battery operated air pump and power supply  (Read 2344 times)
Offline beginnerTopic starter
« on: July 03, 2014, 09:37:56 am »
Hey guys thought you might be able to help me out with this one..  I've got myself an aerobed for camping trips which comes with a rechargeable pump - this pump can be charged from the AC adapter or operated directly from a 12v lighter adapter.  What it tells my I can't do is operate the pump when plugged into AC or damage may result..  I can't really figure out why they've done this but am looking for a workaround.
The car adapter outputs 12v and is rated to 6.6 amps, the wall adapter outputs 12v and is rated to 400mA.  Am I able to trick the pump into not damaging itself when operated from AC by just using a 12v adapter rated to 6.6 amps?
Offline amyk
Re: help with this battery operated air pump and power supply
« Reply #1 on: July 03, 2014, 01:14:01 pm »
Cost reduction. An 80W power supply is a lot more expensive (and probably much bulkier) than a 4.8W one.
The damage they refer to is likely to overloading the adapter. Using a power supply rated for 80W at 12V should be fine.
« Reply #2 on: July 03, 2014, 01:22:47 pm »
too easy, thanks.
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: July 04, 2014, 04:54:50 am »
Adding a series 350mA or so PTC is one cheap way to solve the problem. Still costs too much for production, of course.
