Author Topic: Battery impedance meter, RC battery tester  (Read 2625 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: April 27, 2010, 09:38:19 pm »
Just check this out , and tell me your opinion.
http://motors.shop.ebay.com/service369/m.html?_nkw=Battery+impedance+meter%2C+RC+battery+tester&_sacat=&_trksid=p3911.m270.l1313&_odkw=&_osacat=0&bkBtn=
Is there any alternative way to use an DMM to do the job ?
alm
  • Guest
Re: Battery impedance meter, RC battery tester
« Reply #1 on: April 28, 2010, 09:35:08 am »
Not really, but you could probably rig something up with a function generator and a scope. I believe the principle is the same as measuring the ESR of electrolytic capacitors. The Bob Parker ESR meter is often used for batteries with the protection diodes removed (they'd short the battery terminals).
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: April 28, 2010, 02:08:30 pm »
Its worth it only if you use high current drain expensive batteries.  Do to manually, requires, as alm says, a frequency generator and good DMM.
http://visforvoltage.org/forum/2268-how-measure-internal-impedance-cell-batteries
The only question I have is how accurate is that ebay meter?
I would need to convince myself it does work by measuring Z myself first then comparing it to the meter.
http://www.google.com/url?sa=t&source=web&ct=res&cd=5&ved=0CDMQFjAE&url=http%3A%2F%2Fwww.battcon.com%2FPapersFinal2003%2FLawrencePaperFINAL2003.pdf&ei=Dz7YS5-qB4LY8ASx4IyWBw&usg=AFQjCNGJXzwoBvvtx55--78orrWC-UnKCg&sig2=ccTv25uX_nu5juT9W4QP_A
Best Wishes,
 Saturation
