post 3 of 3On Mehdi's video in particularI don't think anyone doubts that Lewin is ultimately right (he is), but AFAIK he failed to address any of Electroboom's practical points.
From what I have seen, it's Lewin with his fingers in his ears repeating "KVL doesn't hold" 100 times, vs Electroboom trying to methodically evaluate the problem from a practical demonstration standpoint. From that I know who I have more respect for at the very least.
A lot of people asked why hasn't Lewin responded to Medhi's objections. But he did, well before Mehdi's video of three months ago (look at the date: one year ago)
comments by lewin from youtube video LzT_YZ0xCFYLewin also mentioned this fact when he was recently asked why he did not answer to the latest video, saying that he had already addressed Mehdi's misconceptions.
And if you go through the various Lewin's videos on this matter, in the comment sections you will find a single comment repeated over and over (what you would certainly call 'borderline spam'), it's the one above that is dated '3 months ago'.
![](https://i.ibb.co/M9mMQwX/screenshot-5.png)
multiple comment by lewin, post mehdi's video
Guess what: he's not repeating it because he's having a bad senescence episode. He's repeating it because, basically, that's all there is to it.
Lewin: In the case of an induced EMF the potentials in a circuit are no longer determined, they depend on the path
Should he go on indefinitely to answer such basic stuff? I can understand why he stopped doing it.
You make it sound like all this is so plainly obvious, that it's all obviously settled, and "how dimwitted Mehdi's audience is for not noticing this",
Look at the most recent video by Mehdi, "The conclusion"
He tries to put the all thing down to the OLD KVL vs NEW KVL problem. But even there he fails to see the crucial point.
Mehdi@8:08 "
KVL says that the sum of all voltages in a loop must be zero".
So, there you have it. He's saying this looking at the Romer-Lewin ring.
He is assuming you can apply KVL to a varying magnetic field region, or that you can have single valued voltages inside the loop so that their sum has a meaning without further specification. This is the problem.
You can have such single valued voltages
only if there are no varying magnetic fields enclosed by the loop.
This is the part that Kirchhoffians do not understand. They seem to believe that when people tell them that they should not have dB/dt within the circuit's premises, it is implied there has to be no dB/dt at all, anywhere. Sorry guys, but if you had read some serious book on EM you would know that NEW KVL works with varying magnetic fields inside the components BUT still require that there be NO VARYING magnetic field INSIDE the CIRCUIT PATH.
Like other Kirchhoffians, Mehdi is struggling with the concepts of "inside" and "outside".
To pretend that Lewin is mistakenly using the old (pre-Faraday) version of KVL, where there are no varying magnetic fields at all anywhere, is intellectually dishonest. And since a large chunk of Mehdi's audience appears - from the comments - to have bought that line of defense, I wouldn't be so harsh in dismissing the qualifier of "dim-witted" attributed to them by bsfeechannel.
Also, Mehdi should pay attention to what E is. Is it the coulombian field, or is it the total field, sum of the coloumbian and induced parts? It appears to me that Belcher tried to tell him, but he seems not to have understood it.
I could go on with little things like these (that might happen to be just slips of the tongue):
Mehdi@10:22 "
each meter reads the voltage across the resistor on their side"
not quite, the meters read a voltage that is very close to the voltage of the resistor on their side. But that's nitpicking.
Mehdi@11:33 "
if the field is going through the page in that way, the induced current is in this way"
nope, it's not how the field is directed that counts, it's how it is varying. You can have opposite currents with the field always entering the page, depending on whether the field is increasing or decreasing. Not nitipicking, this is an important distinction, but it's a forgivable slip in a long video.
Mehdi@11:40 "
we can split this integral..."
does Mehdi realize that in addition to the endpoints a and b he has to specify the path, as well? It might seem so, but I am not sure at all because of what he says later on.
Or I can get to the real beef that comes at minute 13 or something - when Mehdi mentions Feynman. He says he understood how the voltage across the inductor can be nonzero even if the path integral across the conductor it is made of is basically zero and shows the circuit with the gamma line (fig. 22-9)
Mehdi@13:51 "
and doing so the book shows that the sum of all voltages in the loop is zero and KVL holds"
From the smile of satisfaction (and the triumphant music) I infer that he believes this is proving him right. And he goes on saying
Mehdi@13:58 "
So professor Belcher also concluded that doctor Feynman himself and I have the same definition of voltage and that KVL holds in all cases"
All of this is a load of bullshit. Why? Because in Feynman's book it is clearly stated that THERE HAS TO BE NO VARYING MAGNETIC FIELD
INSIDE THE GAMMA LINE.
http://www.feynmanlectures.caltech.edu/II_22.html![](https://i.ibb.co/DVbp881/screenshot-6.png)
A condition that is
not satisfied by the Romer-Lewin ring.
Inside.
Outside. Different things.
KVL does not hold in all cases (yes, Medhi actually said that
KVL holds in all cases) and neither Feynman nor Belcher have ever written that it does.
And yet Mehdi put that load of bullshit into their mouths and his audience bought it. Hook, line and sink.
Oh, and then he goes on for minutes showing off how KVL is so useful, completely omitting the fact that its usefulness is subordinated to its applicability. Dude, learn to use your tools, but most importantly learn when you can use them.
It looks like he's throwing smoke in the eyes of his audience as if to say: look how useful this thing is! Can you believe Lewin wanted to do away with it?
Professor X is saying I cannot walk on water. But here I am, walking on grass. See? I can even jump and run. Walking is very useful, a lot of runners walk and run every day. Professor Y and Z agree with me.
QED.
This is intellectual dishonesty.
If you do not see this and believe that I have just demonstrated professor X is wrong, well, you are dimwitted.
(Yes, I can see beanflying bleeding from the eyes and bursting into flames)
<pause while someone grabs a fire extinguisher and put off the fire>
And I know it never ends. You have to go till the end of the video, otherwise the dimwitted audience will take that omission as running away from the real explanation that surely will been given from that point onwards. So...
At 14:58 Mehdi even reads Feynman
Mehdi@14:58 "
A separation is made between what happens inside and what happens outside"
Inside.
Outside.
So they really are different things.
Does Mehdi know how important is to distinguish between them?
Mehdi@15:02 "
This is important to know because..."
It seems so! But then:
...even if the field is not contained and leaks outside, we still have an inductor and [??defined??] voltages are everywhere and KVL holds"
Oh, no, it seems he doesn't. But wait:
Mehdi@15:10 "
But this creates huge complexities in our calculation because now the leaking field affects all the components and wires in the circuit that we have to take into account."
Oh, he seems to get it, but wait again...
Mehdi@15:20 "
... which is almost impossible because now there are so many new variables introduced that we might easily overlook".
Actually it's more that you no longer have a single-valued voltage in your circuit (as Lewin tried to tell him) and you need to resort to fields and compute path integral along specified paths. (Feynman says it's almost imposibile when you have hundreds of components, but it can still be done rather easily with the Romer Lewin ring - as a matter of fact, a little bit of vector calculus will show why the voltage along the circuit happens to be only at the resistors)
Did he get it? Let's see:
Mehdi@15:26 "
Our simple loop and probes was the easiest example of uncontained field. The field closes around the entire circuit and affects everything. Every piece of wire and even the resistor itself become and inductor and the secondary of a transformer".
So, it's definitive. He does not get it.
He does not get it that in order to model the components as inductors and secondaries of transformers you need to satisfy the prerequisites for the application of lumped circuit theory. That is, you need for your CIRCUIT PATH to have NO VARYING MAGNETIC FIELDS
INSIDE OF IT.
Inside.
Outside.
Different things.
Q.E.D.
(sounds pompous, doesn't it?)
P.S.
what remains regards avoiding the leakage unwanted flux on the
outside of the circuit (he seems to still be thinking that the multiple valued voltage can be explained with bad probing) and him still falling into the trap of believing there is a voltage developed along the conductor
Mehdi@17:50 "
every piece of wire is an inductor. If we have a voltage V across the main loop we would also have half a V induced on equal length of prove wire exposed to the same magnetic field"
fig a 17:54
A more proper scientist like Romer would say..."
Yes he would say something different because the voltage across an open wire depends on the path along which it is evaluated. And if you go along the wire as Mehdi shows with the movement of his marker (and lack of specification of any other path), it is essentially zero.
To say that there is v/2 on the half arc is the same as saying that there is a build-up in voltage along the coil of a transformer, Mabilde-like. And that is wrong.
But no, the concept of wrong is not allowed.
it is not wrong, but it's a bit misleading"
Of course, wrong is a bad word. How could anything be wrong? Just like the energy flow guy from Science Asylum ("Energy doesn't flow the way you think", youtbue video C7tQJ42nGno) who is propagating the concept that the electric field inside the copper wires is much stronger than immediately outside, where according to him it is parallel to the wires. In the pinned comment he says "
it's not a mistake, it's an educational choice".
Despite the shitload of papers some viewers have posted to prove how wrong he is.
Someone here mentioned the Dunning-Kruger effect. Yes, I guess it plays a role in all these matters. I only wonder where is the threshold: one hundred thousand? five hundred thousand? one million subscriptions?
As I said before, scientific populism is going to be a big problem a few yeas ahead.
Flatearthers, moonhoaxers, antivax and climate change deniers are just the tip of the iceberg.
