By the way. Here is the real thing without the lumping box, in case someone still has some doubts.
Yep that's what it would show without the box.
Notice that the inner voltmeters still show 0.1V and 0.9V? Care to explain why they didn't change regardless of the shielding box being there while others did change?
Of course. Because the line integral along the path that includes them and the wires is exactly the same. In other words, the varying magnetic field that the meters and the wires are encircling is exactly the same. The magnetic field outside the closed path doesn't affect the EMF.
This is what Faraday discovered and Maxwell described mathematically. As simple as that. That's the way nature works. There's nothing we can do to change that. You have to accept it. Not because I'm tell you, but because every time you try to repeat this experiment, it will always work that way.
There is, of course, an explanation for the underlying phenomenon of induction, but it is not the topic of this thread.
I can't see where we are disproving ourselves. We are not claiming anything. We're consistently showing that the claim that Kirchhoff always hold is nothing but quackery.
It always holds in circuit meshes, not elsewhere. Typical word twisting as usual.
NOOOOOOOOOO. Kirchhoff doesn't always hold even for circuit meshes. The inductor itself is a proof of that.
If Kirchhoff always held you couldn't even have inductors, as the voltage inside an inductor, i.e. along the path of the wire, is zero and outside it is different from zero. How can that be?
You don't
understand it because you didn't read Feynman carefully as I recommended you to. This explanation is there.
It's because Kirchhoff fails that we have inductors, generators, transformers, antennas, etc.
Thanks to your favorite deity, or the lack thereof, that Kirchhoff fails. The failure of Kirchhoff is the best thing that could happen to humankind. Every time Kirchhoff fails, the world smiles. (I think I'll create a t-shirt with those words.)
I wonder when you realize that those guys do not have word "agree" in their vocabulary They are ready to disprove their own words - if it is you who is speaking
Yeah this has turned into a Maxwell versus Kirchhoff pissing contest 15 pages ago. But so far i have yet to see a good explanation why the two can't be both used provided you know how to use them rather than just slapping formulas on things without knowing what they actually do.
This is not a pissing contest between Maxwell and Kirchhoff. As Kirchhoff is a special case of Maxwell, the only thing we are trying to show you is exactly that.
