Fine... well I will do a full dissection of the all the mistakes Mehdi makes:
At 5:47 Mehdi claims that in a twisted wire there is induced current inbetween each twist that cancels out the one in the next twist. This is false. The cables cross over for each twist, they do not connect, so there is no induction loop in the 'circle' of each twist. The reason twisting cables stops induction is because as you twist the cable, you are flipping the area of the loop over. So the magnetic field is now effectively passing though the next twist upside down. So the magnetic field through the first twist is in one direction, and the magnetic field through the next twist is in the other direction - when you consider the plain the loop made up by the wire run. So by twisting you can make the net field through the overall loop zero - therefore no induction.
At 8:18 Mehdi measures the current 'across both resistors'. Mehdi then concludes that voltage R1 plus voltage R2 is the same as voltage across the loop. In adding the volt meter across R1 and R2, Mehdi has changed the topology of the circuit. It now has 4 loops instead of 3. Most importantly, the meter is now in the inductive loop, not the resistors. Mehdi is oblivious that he has done this. In this case the voltage around the loop is the voltage shown on the meter. By adding the voltage meter here there is no longer any induction in the smaller loop containing the resistors, as that smaller loop does not enclose any of the magnetic field.
At 9:10 he admits that if the meter is put on the out side, re-forming the original induction loop with the resistors in it, that the voltage again goes to zero. He then asks who is correct. Obviously it is Lewin who is correct, as Mehdi is oblivious the he changed the topology of the loops when he measured what he is calling the 'loop voltage'. With the circuit back in its proper arrangement, he measures as per Lewin. Ironically it is Mehdi who is doing 'incorrect probing' here.
At 9:27 his inability to think of the inductive loop is shown further at 9:27, when he claims to be 'measuring across the gap'. Of course he is just completing a loop with his meter.... there is no gap. Once again he is obvious to his own incorrect probing....
At 9:42 he then runs the meter the other way, so there is no loop around the magnetic field, and he reads zero. He later attributes this to 'cancelling out', but there is nothing to cancel out, as he has formed no loop around the magnetic field.
At 9:49 he claims if he makes the sense lines 'a little bit shorter' than the loop, but without crossing (or encircling) the magnetic field in soleniod, and says "I will have voltage jumps". This shouldn't happen of course because he doesn't have any loop around the magnetic field inside the soleniod. The reason he reads a bizzare wave form here is because there is a weak magnetic OUTSIDE the soleniod (imaging it come out the top stretching to infinity as it spills down and comes back in the bottom of the soleniod). The thing he is measuring at this point is actually the magnetic field 'falling' through his loop in the opposite direction as the magnetic field through the solneiod. This is why his wave form is opposite to when he just measures around the soleniod. He incorrectly attributes this to the meter probes no longer 'canceling out' properly. You can see plainly that he has made a fork shape loop, and he puts his loop in the worst possible position: over the end of the soleniod while not enlcosing the magnetic field inside the soleniod. Lewin explains how you need at least a 30cm soleniod with your loop half way down, the point of this is to ensure the magnetic field outside the soleniod is for practical purposes zero. Mehdi has a complete failure of experiment setup here. You can replicate it yourself, if you have any fork shape loop around the soleniod (but not enclosing it) you read zero. Start moving it up to the end of the soleniod and you will start getting induction in the OPPOSITE direction compared to when you enclose the soleniod.
At 10:00 to 10:27 Mehdi makes the extraordinary claim that a non-closed loop will have half V induction, cancelled out by half V the other way. He never produces a single measurement to show this is true. If his claim was correct, he could measure the Half V by putting meter across left and right sides of the 'semi circle' he shows. This is of course complete garbage. There is no loop formed around the magnetic field, so there is no induction.
At 11:18 Mehdi claims "the same voltage of the loop wire are induced on the sense line". The sense lines are on the left and right side loops, which enclose no magnetic field, so there is no induction involving them. The induction loop is just the inner loop with the resistors. He is 100% wrong about induction 'in' the sense lines.
At 12:02 the proof of Mehdi being wrong is made final when he shows a circuit claiming to show "properly" how to measure the voltage across the loop. Once again this just changes the topology of the circuit. By bringing the probes through the middle he is now creating two induction loops, the left loop and the right loop, each enclosing half the magnetic field. Only this time HIS METER PROBES ARE PART OF THE INDUCTION LOOP. So he has gone from the original Lewin circuit that had no magnetic field through the left and right loops that contain the meter probes, to a circuit with only two loops, both of which form an inductive loop by using the meter probes. Yet he claims it is Lewin who incorrectly probed
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
He overall main mistake is that for some reason he thinks voltage must exist across the wire portion of the induction loop. This is because he is used to thinking of circuit elements in conservative fields, which have a voltage drop across them. He out right says it himself when he claims Lewin 'forgot' the 'transformer'. He has no idea at all when it comes to non conservative fields, not even the most basic requirement of a closed loop around the magnetic field being required for induction.... Throughout his video he is completely obviously when he creates new induction loops and changes the topology of the circuit.
In all seriousness... has anyone checked this guy even is actually qualified? Is it just a show? His videos are entertaining but his video on this is absurd junk science. What is scary is the amount of people on here, and youtube, and reddit, who are siding with Mehdi...
