Author Topic: What would you like to invent?  (Read 248 times)
Offline BrynTopic starter
    • mindsConnected
« on: Yesterday at 07:00:32 pm »
I know there's a fair share of budding inventors here that build things for fun but, for those that actually want to take this sort of thing more seriously and hope to make things better for everyone or simply to revolutionise basic concepts, what would you create?
For me, I would invent an alternative for taking blood pressure, particularly one that doesn't have to squeeze one's arm to take it (as to me causes discomfort, and at times can give inaccurate readings even from the patient making slight motion).
I've recently thought of it of having a large ring-like design where it can adjust to the circumference of the patient's upper arm like for the basic cuff but instead of having it squeeze the arm to get the readings (and the pulse included), I'd have it "read" the systolic and diastolic levels instead, although that may sound impractical. I'd think more thought would have to be put on that should it be a successful product...
So, what about you? :)
mindsConnected
Alternate tech forum for all... recently reopened (as of 15/9/24)
We welcome engineers also!
Offline fzabkar
Re: What would you like to invent?
« Reply #1 on: Yesterday at 09:49:28 pm »
GM grass that never grows higher than a golf club's lawn.
Online SiliconWizard
Offline tom66
« Reply #3 on: Yesterday at 09:59:10 pm »
A genuine solution to climate change that doesn't involve massive compromises from everyone and so actually happens.
A bit like how we fixed the hole in the ozone layer because we found refigerants that were better than freon in nearly every respect so there wasn't that much pushback against them.
Online Alex Eisenhut
  • Place text here.
« Reply #4 on: Yesterday at 10:07:15 pm »
Active noise cancelling windows.
Offline David Hess
  • DavidH
« Reply #5 on: Yesterday at 10:42:26 pm »
We already have that.  Emo-grass cuts itself.
« Reply #6 on: Yesterday at 10:53:58 pm »
There are already some companies working on "cuffless" blood pressure sensors. Like this one:
https://valencell.com/our-product/
Note that this isn't FDA-approved yet and is not formally clinically-proven, so that's not a replacement, but could be interesting already if you need to take it very frequently.
They use photoplethysmography, like pulse oximeters, with some dedicated algorithms.
Online Andy Chee
« Reply #7 on: Yesterday at 11:01:11 pm »
A camera/microphone that recognises deception (in the same manner as facial recognition, voice recognition, gait recognition, etc)
Essentially a modern lie detector, but without the intrusiveness of breath rate and galvanic skin sensors.  Should be compatible with existing CCTV infrastructure.  Should be compatible with smartphone cameras/microphones.
Offline K5_489
« Reply #8 on: Yesterday at 11:18:10 pm »
I mean...I could tell you...but then I'd have to kill you... :-//
Like I'm gonna just give away all my million dollar ideas???  :-DD
