Poll
When charging/dischargin a capacitor through a resistor, what waveform does the voltage have?
the voltage smoothly changes, following an exponential function
36 (73.5%)
the voltage changes in small jumps, looking like a stair with many steps
5 (10.2%)
neither (explain how)
7 (14.3%)
don't know
1 (2%)
Total Members Voted: 49
Author Topic: Does a capacitor charges smooth, or in stairs?  (Read 8575 times)
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
Re: Does a capacitor charges smooth, or in stairs?
« Reply #75 on: June 24, 2020, 07:06:35 am »
This time error showing a negative back step is only a few pixels.  I would think this is due to time problem between the speed of the screen video timing and the main time base are out of sync by a few pixels.
Could be a component delay or a small error in the Dac division..
If its real you have found a way to travel back in time  :-+ which is really good .
I think you are pushing your scope .
And with all electronics there will be one part that may be not 100% up to spec.
I would check your video memory  maybe getting hot..
Have fun
RNS
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
