Author Topic: DIY AA Batteries  (Read 1944 times)
Offline StonentTopic starter
DIY AA Batteries
« on: December 21, 2014, 09:02:34 am »
This is a really good channel if you are interested in chemistry. I think it would be fun to see how much current these home-made batteries can produce.
« Last Edit: December 21, 2014, 09:07:23 am by Stonent »
Re: DIY AA Batteries
« Reply #1 on: December 21, 2014, 01:48:11 pm »
No depolariser, so it will only deliver a constant current of around 10mA for long periods. As well it will dry out, and is in no way leakproof. However if you use a small tyvek bag to hold the MnO2 and graphite, and use some steel plate as a current collector plate with a zinc plate anode each side of the plates in contact. Place in a plastic box and add electrolyte and it likely will run a clock for a decade or more if you seal the top with wax and have a small porous ceramic plug for pressure relief.
