Here's a short animation to help visualizing what I was trying to explain:
- viewable range increases each day
- space expands with time
- speed of light is considered constant
Space expansion is not much, but over huge distances it all adds up while the speed of light is said to stay the same, so after enough distance the expansion will become faster than light. As a result, more and more stars are leaving our viewable range, even they are still shining.
The Pale Blue Dot is the Earth, the red dot is the outpost with a telescope broadcasting what it sees from the outpost viewpoint. At some time in the future, even the outpost will run out of our reach, but for as long as the outpost is in our direct view, then we will receive what the outpost transmits (the view of all the stars inside the red circle), some of each we wouldn't be able to see without the outpost, because they are outside our green circle of direct view.
Note how the circle of view slightly increase in size, yet stars keep migrating from the inside to the outside of any circle.
#!/usr/bin/env python2.7
How to look outside our observable Universe using an outpost:
- the WHITE dots are the stars
- The Pale Blue Dot is the Earth
- the GREEN circle is the obsarvable Universe, looking from Earth
- the RED dot is an outpost telescope, continuously broadcasting its view
- the RED circle is the observable Universe, looking from the outpost
- note that the circles' radius increases with time, at the speed of light, c
- note that even the observable radius keeps increasing,
with time the stars are leaving the observable circles because space expands
- note how with time, will be less and less stars to view,
even thought the stars are still shining out there,
just that they are running away faster than the speed of light
- by receiving the broadcasted view from the outpost,
we will be able to study all the stars seen by the outpost,
including the stars that otherwise will be outside of our direct reach,
but are still reachable from the outpost viewpoint
- after a while, even the outpost will run away outside our view
import pygame as pg
import random
WIDTH = 1920
HEIGHT = 1080
ANIMATION_FPS = 10
WHITE = (255, 255, 255)
BLACK = (0, 0, 0)
RED = (255, 0, 0)
GREEN = (0, 255, 0)
BLUE = (0, 0, 255)
LIGHT_BLUE = (32, 64, 255)
NR_OF_STARS = 2000
INFLATION_COEF = 0.01
OBSERVABLE_START_RANGE = 200
class Dot:
def __init__(self, x=0, y=0, color=WHITE, thickness=3):
self.x = random.randrange(1, WIDTH-1)
self.y = random.randrange(1, HEIGHT-1)
self.color = color
self.thickness = thickness
self.x_now = self.x
self.y_now = self.y
def __call__(self, x, y, color, thickness):
self.x = x
self.y = y
self.color = color
def xy_now(self, time=0):
self.x_now = int(round(self.x * (1 + time * INFLATION_COEF)))
self.y_now = int(round(self.y * (1 + time * INFLATION_COEF)))
screen = pg.display.set_mode((WIDTH, HEIGHT))
pg.display.set_caption("Observable vs Expansion")
clock = pg.time.Clock()
light_day = 1
# populate the Universe with stars
random.seed(1)
stars = [Dot() for i in range(NR_OF_STARS)]
# add Earth to the Universe
Earth = Dot()
Earth(200, 150, LIGHT_BLUE, 10)
stars.append(Earth)
# add an Outpost to the Universe, inside the viewrange of the Earth
Outpost = Dot()
ox = Earth.x + int(round(3.0/4.0 * 2**0.5/2 * OBSERVABLE_START_RANGE))
oy = Earth.y + int(round(2.0/4.0 * 2**0.5/2 * OBSERVABLE_START_RANGE))
Outpost(ox, oy, RED, 5)
stars.append(Outpost)
# animation loop
stopped = False
while not stopped:
# Frames Per Second
clock.tick(ANIMATION_FPS)
for event in pg.event.get(): # User did something
if event.type == pg.QUIT: # If user clicked close
stopped=True # Flag that we are done so we exit this loop
# Clear the display buffer and set the screen background
screen.fill(BLACK)
for star in stars:
# Update the star positions as per today's view and draw the star
star.xy_now(light_day)
pg.draw.circle(screen, star.color, [star.x_now, star.y_now], star.thickness)
# Draw today observable ranges from Earth and from Outpost
pg.draw.circle(screen, GREEN, [Earth.x_now, Earth.y_now], OBSERVABLE_START_RANGE+light_day, 1)
pg.draw.circle(screen, RED, [Outpost.x_now, Outpost.y_now], OBSERVABLE_START_RANGE+light_day, 1)
# Display the screen buffer
pg.display.flip()
pg.image.save(screen, "frame" + str(light_day).rjust(5, '0') + ".png")
# A day passes with each frame
light_day += 1
pg.quit()
