Author Topic: World's Brightest LED in a Flashlight! Cree CXB3590  (Read 4052 times)
Offline Homer J SimpsonTopic starter
« Last Edit: September 25, 2018, 09:20:50 pm by Homer J Simpson »
Online ebastler
Re: World's Brightest LED in a Flashlight! Cree CXB3590
« Reply #1 on: September 25, 2018, 09:42:37 pm »
I watched most of it. Did he mention battery life? Heat management?
A bit more engineering content would have been nice...  ::)
Offline stj
« Reply #2 on: September 26, 2018, 05:24:31 pm »
20 times the power consumption of a chinese overdriven T6 lamp,
10 times the cost.
and you need 36v - not exactly a wise choice for a handheld!
maybe better for car/truck headlamps - obviously designed from the ground up - not a retrofit!!
Offline floobydust
« Reply #3 on: September 27, 2018, 01:00:03 am »
$38 USD each. How do you heatsink this? 87W typical and 137W max. for 2.4A typ. and 3.6A max. at 34-38V.
It has no mounting screws (like the CMA series) and flashlight guy used some glue... oh I found the silly holder pic below.
It looks like a great powerful LED with Cree's high quality.
I'd like to try one (dimmed) for task/bench lighting but it's an expensive solution, including holder, heatsink, power supply.
There are some light fixtures on eBay/Ali using this CXB3590 LED for grow lights.
I tried the high-power chinese 50-100W LED's and found the light quality was poor. Fringing, low efficiency, colour temp shifting all over the place, lens is like beer goggles.
It's hit or miss with vendors. I just didn't like the LED's enough to go further with them.
An option is Cree XLamp XHP70 array 6V 2.1A 12.6W and ~1,600 lm which almost 1/10 the flux of the CXB3590's ~13,000 lm. I guess you could use a bunch of these XHP70's on m-core PCB but kind of a narrow spot each.
« Last Edit: September 27, 2018, 01:01:47 am by floobydust »
Offline firehopper
« Reply #4 on: October 14, 2018, 03:25:26 am »
well i bought one from rapidleds, its here and i got the holder too. now to mount it and do some testing. need to get a light meter some time too
Offline firehopper
« Reply #5 on: October 14, 2018, 04:16:23 pm »
https://www.flickr.com/photos/firehopper/43500527710/in/dateposted-public/
heres my led mounted on the heatsink for the flashlight build :)
I'll fix the link later
« Last Edit: October 14, 2018, 04:19:24 pm by firehopper »
Offline james_s
« Reply #6 on: October 14, 2018, 05:04:23 pm »
Several years ago I modified a 3-D Maglight to use a Phlatlight LED that was at the time the most powerful single LED available, 2200 lm driven at 11A. I turned a large block of aluminum that fits snugly in the Maglight body with a pocket for the driver and then used 3 LiFePO4 cells for power. It works well and can run for a couple of minutes at full power before it starts to get uncomfortably warm.
It's not the most practical flashlight in the world. I look at it more like a V8 powered lawnmower, complete overkill, built because it could be done.
Offline mzzj
« Reply #7 on: October 14, 2018, 05:37:15 pm »
Most powerful led?
This one is 30 klumen https://www.bridgelux.com/sites/default/files/resource_media/Bridgelux%20DS93%20Vero%2029%20Gen%207%20Array%20Data%20Sheet%2020180910%20Rev%20N.pdf
One guy around here build bicycle light out of 4x Bridgelux Vero 29 led arrays..  120klumens and 1kW of electrical power  :-DD
Offline james_s
« Reply #8 on: October 14, 2018, 09:43:59 pm »
Those are COB arrays though, which of course would work but that sort of thing was not really common when I built the light I have. The ~40W LED I used was the most powerful single LED I could get back then. Now I'm sure there are brighter options. I'm not sure those COB arrays would offer great optical performance though, a single small emitter allows an ordinary reflector to produce a very sharp beam with a lot of throw.
Offline amyk
« Reply #9 on: October 15, 2018, 12:01:56 am »
"Flashlight"? That's more like a "torch" :o :-DD
Offline firehopper
« Reply #10 on: October 15, 2018, 11:02:48 am »
well I consider it a light cannon my self, mines going to be housed in a 105 mm howitzer casing.
Offline firehopper
« Reply #11 on: October 17, 2018, 03:01:23 am »
well heres some photos of the flashlight so far.. needs a reflector yet.
https://www.flickr.com/photos/firehopper/albums/72157700957050681
