Author Topic: dI/dt ? math error?  (Read 3617 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
dI/dt ? math error?
« on: July 11, 2013, 09:45:58 pm »
I checked an integration 'error?'  in my book . See the red  !  .
Unfortunately the book is in french.  Anyhow . . .
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline c4757p
  • adieu
Re: dI/dt ? math error?
« Reply #1 on: July 11, 2013, 09:56:58 pm »
Yeah, should be -1/3 ln |5-I|. Somebody missed a factor of three...
In my experience you don't usually make it far into a textbook with a bunch of math before you find an arithmetic error. Maybe my school just picks shitty books, though...
Offline IanB
« Reply #2 on: July 11, 2013, 10:13:14 pm »
Hmm? Let's work it backwards:
f(I) = -1/3 ln(15 - 3I)
Let u = 15 - 3I, then df/dI = (df/du)(du/dI), where
f(u) = -1/3 ln u
So:
df/du = (-1/3)(1/u)
du/dI = -3
df/dI = (-1/3)(1/u)(-3) = 1/u = 1 / (15 - 3I)
Which is what the book has.
So what did I get wrong?
« Last Edit: July 11, 2013, 10:16:24 pm by IanB »
Offline c4757p
  • adieu
« Reply #3 on: July 11, 2013, 10:27:46 pm »
Actually, you're right, thank you!
The catch here is that we came to different answers through different methods, but both are correct because of the constant that is being ignored.
ln(5 - i) = ln(15 - 3i) - ln(3)
And ln(3) is of course a constant.
(I used a lowercase i for legibility)
Kind of ashamed I missed that, I used to grade math papers... :-[
« Reply #4 on: July 12, 2013, 02:43:43 pm »
Why not that way?
 integration sign ((1/ (15-3i) ) dI) =
 ln|(1/ (15-3i) | =
-ln|(15-3i) | =
-|15-3i|  = e^(t-C)
and be stuck with no 1/3  :-/
Offline IanB
« Reply #5 on: July 12, 2013, 03:05:39 pm »
Why not that way?
ln|(1/ (15-3i) | =
-ln|(15-3i) | =
-|15-3i|  = e^(t-C)
Because your working is wrong at the line indicated in red. The antiderivative of 1/x is ln x, and you are missing a factor of (-1/3):
http://www.wolframalpha.com/input/?i=integrate+1%2F%2815-3i%29+di
« Reply #6 on: July 12, 2013, 04:36:32 pm »
substitute u = 15-3 i
du/di = 0-3
and  du = -3  di:
du/-3  =  di
1/-3 *du  =  di
ok
-1/3 log(15+3i)) constant  = t- C
-1/3 log(15+3i))  = t- (C +constant)
log(15+3i))  =-3( t- C)
Why Wolfgang say?
Substitute back for u = 15-3 i: = -1/3 log(-3 (-5+i))+constant
Which is equivalent for restricted i values to:
Answer: |
 |  = -1/3 log(5-i)+constant
Offline IanB
« Reply #7 on: July 12, 2013, 04:44:24 pm »
du/di = 0-3
and  du = -3  di:
du/-3  =  di
1/-3 *du  =  di
ok
Be careful with your signs. In several places there you have changed a "-" into a "+". If you do that in a real problem you will lose marks in a test, or build something that doesn't work the way you expect...
Offline KJDS
    • my website holding page
« Reply #8 on: July 12, 2013, 05:22:36 pm »
For a long time, almost every paper and book I read had errors in the equations, probably so that those who don't understand the maths can't make use of them.
