Author Topic: FLUKEs are everywhere - electrical engineering on container vessels  (Read 2954 times)
Offline Herr R aus BTopic starter
    • World Trip 2012
Just returned from one of my voyages on container vessels (http://blogs.herrrausb.de/fotoblog/?page_id=5850) and what do you know? also there they are using FLUKE multimeters. in this case wile fixing the ship's intercom and some problems with the navigation signal lights - neat!  :-+ see attachments...
Offline vinicius.jlantunes
  • Country: br
Re: FLUKEs are everywhere - electrical engineering on container vessels
« Reply #1 on: January 20, 2016, 03:25:06 pm »
if my wife saw this meter she would not regain piece of mind until it looked yellow again.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: January 20, 2016, 04:04:35 pm »
Fluke DMM's are popular in marine use from its bullet proof reputation, particularly in electrically dirty shipboard environments.  Add to it gear cannot be replaced until you reach port, and that erroneous readings in mission critical electronics can be a catastrophe, highest reliability is required.
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/msg823175/#msg823175
Some explanations of this need.  Now, from all the vendors in the above thread it appears Brymen design can be a true competitor for such use, if it competes well in production batch defects and survives ship conditions such as high humidity and temperature shifts from port to port.
Best Wishes,
 Saturation
Offline Lightages
  • Canadian po
« Reply #3 on: January 20, 2016, 04:47:27 pm »
If you want a meter for mining, on board ships, trips to completely inaccessible areas with extreme environments, then the options are probably the Fluke 28IIEX, Amprobe HD160, and maybe a Brymen. Brymen does not make intrinsically safe meters, nor are they IP rated so their suitability in extreme environments are not guaranteed. They are not suitable for mining operations where intrinsically safe ratings are needed. They are very well sealed and protected from environmental contamination though.
    • World Trip 2012
« Reply #4 on: January 20, 2016, 06:39:48 pm »
Jep - the first thing i thought was: man, this piece of equipment looks used ;-)
Offline nanofrog
« Reply #5 on: January 21, 2016, 12:30:26 am »
I'd add the Gossen Outdoor (IP65) and suspect the new the Agilent U1282A would hack it as well (IP67 rated).
