I've completed a 'QC' safety inspection, basic circuit analysis and performance test on the 120V unit I received, and I'm impressed it works so well for something so cheap. Once you get the bugs ironed out, its well worth the $63 I paid.
More later, but here are key items.
I've re-viewed Dave's good video. I'm not sure who cloned who, but there are subtle build difference between WEP/Yihua versus Atten, or it could be these are 120V versus 240V models. If you need 120V, you must buy the 120V unit as the heater is mains powered.
Operation principle:
The unit is basically a mains powered hair dryer, with a "light dimmer" style Triac to adjust temperature to the heater, and the speed knob is a variable resistor that just reduces VDC fed to the fan. A uC receives feedback from the heater sensors to maintain output temperature as dialed in.
Here are the key issues:
WEP units have Yihua labeled PCBs, Dave's Atten had Atten labeled PCBs and used a different uC
"120V" units have different transformers, in my case a 110V/50 Hz labeled one
The heater assembly is for 110V
The heater assembly has a temperature sensor than maintains output temperature once dialed in
The handset interface PCB has some exposed parts that were shorted with solder debris when I received mine, I had to clean it up and cover it with liquid insulator
The power switch was connected to the neutral line, I re-routed it to switch the hot line
The heater shroud is grounded, so are all exposed metal parts
The dialed in temperature needs to be calibrated to properly read output in Celsius
