Author Topic: DC555, a discrete 555  (Read 2606 times)
Offline nitro2k01Topic starter
« on: February 22, 2013, 02:17:38 am »
Do you think the humble 555 timer is too compact or too accurate? Do you find the pin spacing of a DIP 555 to be just too small for your needs? Or have you wished that you could lift the hood off and look inside?
Enter the DC555, a discrete version of the age-old chip. It's yours for only 1500 yen, about US$16.
I think Dave should buy this kit and compare it to the real deal in various circuits.
http://cart06.lolipop.jp/LA01994087/?mode=ITEM2&p_id=PR00102220444
Offline BravoV
  • +++ ATH1
Re: DC555, a discrete 555
« Reply #1 on: February 22, 2013, 02:41:59 am »
I think they should add these at their ad :
- Much-much higher source/sink current capability than your ancestor's 555.
- Should you blew up the output transistors, you could easily replace it with beefier one with lower Vce sat version rather than have to replace the whole IC. Think green.  ;D
- Improve accuracy ? No big deal, just replace the 3 voltage divider resistors with higher precision & lower temp co version, you will have an "elite" version of 555.
 :-DD
« Last Edit: February 22, 2013, 04:59:29 am by BravoV »
Offline Psi
« Reply #2 on: February 22, 2013, 02:54:54 am »
Next up... a 555 timer out of vacuum tubes.
Better clear off the kitchen table to make room.
Offline Gall
  • Country: ru
« Reply #3 on: February 22, 2013, 08:35:26 am »
Why not use these?
The difficult we do today; the impossible takes a little longer.
